Question about Canon PIXMA iP2000 InkJet Printer
Canon Pixma iP2000 wont print black ink?
I have a Canon Pixma iP2000 and I have refilled both ink cartridges and done several deep cleaning, however it still does not print the black. Any ideas? I urgently need to print my engagement invitations. Thank you :)
  • 4,041 Answers
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Feb 18, 2010
The black ink keeps drying up and will not print out black print
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 03, 2013 | Canon Cli526 Black Cyan Magenta Yellow 3x...
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Black BCI 24 does not print after replacement.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 10, 2010 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma ip2000 Inkjet printer wont print black. Replacing cartridge did not fix the problem.
Remove ink cartridges,then print head.
Clean print head with dry cue tips.
Apply strong suction over black print
jets on print head.
Replace print head and cartridges.
It worked for me.
Oct 17, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma won't print
Sounds like you need a new printhead.
QY6-0054-000. around $40.00
Jul 03, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Feb 26, 2009 | Canon PIXMA iP3500 Printer
Canon pixma iP2000 no yellow will print
Have you tried cleaning the ink pads on the print head using a can of compressed air and blowing from the inside outwards, taking the print head off first. You can usually buy a tin of compressed air in somewhere like PC world.
Dec 01, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma iP2000
try cleaning the print head as follows, otherwise a new print head.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 28, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
1,064 people viewed this question
old marine
old marine
