Question about Maytag MZD2766GES Side by Side Refrigerator
Our freezer has been running nonstop to refreeze everything and now it is blowing warm air. What do we do? Unplug for a break or just shut the door?
We have two upright freezers. We think the door was left open on one and some things were thawed. We shut the door but nothing refroze so we moved everything into the other freezer which packed it. Well now the other one is having issues. we don't know if one of the items was keeping the door from from shutting completely, but now some 1/2 of the stuff in there is thawed. the first freezer is now working fine after a few days, so we moved a few things back into it. but I am not sure if the second freezer is blowing out cold air. Should I keep the door shut and unplug it so that it can have a break from running nonstop. Or should shutting the door fix the problem? Please help. I don't want to lose a freezer half full of meat. thank you. Nicole
  • Peter Stearns
    Peter Stearns May 11, 2010
    I think your first freezer has a defrost problem. I would guess that when you emptied it, you turned it off, so that it defrosted some and began to work. With a defrost problem, it gets so full of frost, air doesn't circulate. Giving a freezer a rest doesn't do anything, provided the defroster is working correctly. If that is working, it gives itself a rest three times a day and a heater comes on and melts the frost.
    My guess is that the defrost timer needs to be replaced on the first freezer. But you can test that by manually turning the defrost timer with a screwdriver. The timer is located under the freezer (I think) accessible from in front near the floor. There is a little hole on the face of the timer. You can put a screwdriver into it and turn a wheel until the timer clicks. Then it should be defrosting and you'll get water out onto the evaporation tray. If this works, wait half an hour or so and turn the timer some more, turning off the defroster. Then go buy a new timer and install it.
    It could be that your second freezer is just too full to circulate cold air.
  • 3,267 Answers
Have u checked the thermostat setting? Set it as u usually do and if indeed the door was left open, then try shutting it down for(unplug) 10-12 Hrs and see if behaves normally after wards(set the thermostat too).
If not then have the thermostat replaced.....sodeep
Posted on Jun 02, 2009
I CANT OPEN THE FRENCH DOOR
My guess it that they are frozen shut which means the little door heaters are not working or you have a bad door gasket. If you have a hair dryer I would blow it around the seams of the doors until they give. Or you can unplug the frige and let it thaw for a bit then try. Or the break between the frige air and the freezer may be frozen closed then the pressure difference can hold the doors shut, in that case you need to unplug it for a bit and try opening the doors periodically
Sep 06, 2012 | LG LFC20760 Bottom Freezer French Door...
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
Bottom mount Freezer Iced up
if you have frozen water droplets on everything most likely the door was left open and when the warm air mixes with the cold air in the freezer this happens,look at the top of the door or the sides of the freezer door,also up on the ceiling where the light switch is,if there's ice there the door was left open,common problem with freezers on the bottom,you can shut down the machine,and with a hair dryer blow the hot air into the vent holes in the back inside wall of the freezer and if ice is on ceiling melt that out too.good luck.
Jul 09, 2012 | Kenmore Refrigerators
Kitchenaid fridge, french door, bottom freezer. Freezer door was left open, now rails for ice bin remain frozen, difficult to pull out.
take the food out of the freezer,shut down the machine or just unplug it,get a hair dryer and hit the tracks and check the ceiling where the light is,usually ice builds up there to if the door was left open.also blow the air at the back wall,the air ducts could have froze up and the fridge will get warm,all it does is there's a fan in the freezer and it blows cold air from the freezer up and into the fridge section,sometimes depending on how long the door was open is the air ducts freeze and the fan can't blow the air up into the fridge,the tracks shold melt out fast then wipe them down but i would hit the back wall for a while until you don't see any water dripping down through the slots in the back wall,should take you no more than around 30 to 40 minutes to do this,hope this helps and good luck.
Sep 06, 2011 | Refrigerators
Have a GE Model #GSL22JFPHBS side-by-side refrigerator that the freezer is staying cold but the refrigerator part is not get cold.
its either the defrost heater or defrost thermostat or the defrost timer has gone bad and the evaporator is iced over,HINT: (you will see the inside rear panel in the freezer has frost on it) and the evaporator fan cannot blow cold air over the iced up coils in which case soon the freezer will start to seem warm too,if this isnt the case then its the damper vent door located between the freezer and fridge compartment that opens and closes to throttle cold air into the fridge from the freezer,sometimes they freeze shut from condensation or the door hinge breaks and it can jam shut,also if theres excessive water dripping into the fridge from the top it can be a plugged drain hole and water blocks cold air flow,also make sure the evaporator fan beneath the evaporator coil in the freezer is operating when the units running or cold air wont be pushed into the fridge either
Jun 27, 2011 | Refrigerators
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Freezer door was left open, now after one day freezer is not cold
you can unplug it and let it defrost on it's own or you can melt out the air ducts,you'll have to shut down the freezer,remove the shelves and remove the inside back wall of the freezer section and melt out all the ice in the right hand corner and any ice on the coil.when melting out the air ducts be careful not to damage any of the plastic or styrofoam on or inside the wall,heat up the area with a hair dryer for a couple of minutes and then move to the coil,after a minute or two go back the the air duct,when you think it's melted out enough turn the freezer back on and with your hand check to make sure the air is blowing into the fridge side,if you can feel air blowing then your all set,if there's any ice left in there the defrost will take care of it.if you have another fridge to put your food in or if the food can't be refrozen i'd just unplug it and let it melt out on it's own over night and you can clean it out while everything is out of it.let me know how you make out and good luck,hope you didn't loose that much food
Jun 06, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
250 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
