Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler command cv15s starter sping in the opposite direction???
Is it possible? could the new starter be wired wrong?
  • 376 Answers
It's more likely you hooked the battery up backwards. That reverses the polarity and will make the starter spin backwards.
Posted on Jun 02, 2009
Does the commutator end cap part # 12-227-11-s clamp on to your old bruches?
If you had it apart and know your brushes are good, you could just order the part specified, but if I was you I would get the part and the brush kit. The brush wire actually has an eye fitting that bolts to the cap. You might have a pinched wire or, the wires might be brittle and when you go to remove the brushes, could break apart.
For your parts, google the number along with Kohler and see if you cant get it cheaper from somewhere else. In my experience, Sears is only comparable if they stock it in store and you live near by.
Aug 05, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stuck on incline error code 45
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Feb 16, 2014 | Precor Exercise & Fitness
Need help with KOHLER COMMAND 15.5 hp (model no.cv15s)
Are you sure the anti fire solinod in the bottom of the float bowl is working as this will shut the fuel off to the main jet, remove it, now switch the ignition on, the needle should retract fully into the housing, failing that there has to be some dirt in the jets, perhaps you could get the carb sonic cleaned this should help to unclog any jet orafices
Jun 15, 2013 | Craftsman Garden
What is error 45 on the EFX 546??
Nov 11, 2012 | Precor EFX 546i Elliptical Version 4
Hello I have an error 45 what is this?
hi,
Error 45 means the lift moving in wrong direction.The lift control system has detected that the lift is moving in the opposite direction of the issued lift command. There are two possible causes they are,
1- Lift Motor hysteresis.
This error would typically happen when the lift was already in motion (typically downward) when a lift command in the opposite direction (lift up) was issued. Some motors exhibited a very long turn around time and the lift motor would still be moving in the original direction (downward) while the control system was attempting to move the lift in the opposite direction. If the error 45 condition is persistent, replace the lift motor.
2 - Bad lower PCA
This is a very rare condition, if the lift moves in the opposite direction of the issued lift
command, replace the lower PCA
ok
Jul 15, 2011 | Precor 956 Remanufactured Treadmill
I have a 27 kolher command pro on a mud motor in cold weather when i go under load only it makes a knocking noise and stalls out. it runs like ****. i have taken it places and they say theres nothing wrong...
you know the accelerating arm?...well...it's connected to a spin-able metal cylinder that goes into the engine.....regulating that cylinder's connection to the arm can solve this problem..
-regulating procedure:::---
unscrew the nut that keeps the two connected...then.
1- if by (runs like ****) you mean too slow//...then.spin the cylinder to the direction that accelerates the engine(very slowly).
2- if you mean too fast them spin it to the opposite direction.
it's a dificult procces even for some experts.
Sep 28, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
408 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
