Question about Whirlpool GSW9800PW Washer
E0 F2 Error on Whirlpool Gold Super Capacity 465 Oven
I have a whirlpool accubake 465 oven. The stove top works fine, however I get an E0 F2 error shortly after turning on the oven. I have read I need to change the keypad out. The diagnostic packet in the back of the oven says "ensure the membrane tail is seated in the connector on back of control". I would like to find a diagram to show me what the membrane tail looks like.
One note that might impact the oven. The casing behind the oven light bulb is brown like the bulb burned out at one time. The white casing surrounding back of the bulb is also brown in some areas. After taking the bulb out and replacing it the oven worked fine for about 24 hours. The oven turned on and the E0 F2 screen was gone. After about a day it came back however.
Please let me know what options I have in repairing the oven. Thank you.
Jake
  • 530 Answers
It's green and it is connected in the console area. the touch panel is what needs to be replaced take the back panel off sometimes if you get a pencil eraser and clean the end of the ribbon cabbel that helps but more than likley you need to replace the touch panel.
Posted on Jun 02, 2009
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: E0 F2 Error on Whirlpool Golf Super Capacity 465 Oven
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Posted on Oct 01, 2010
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
We had a minor stovetop fire and getting the E0 F0 error code. The oven is a whirlpool gold super capacity 465.What is there to do about this?
E0 F0 is a communication failure within your control board/ eoc. If it does not reset after a 30 second power down, the board will have to be replaced
Sep 19, 2009 | Ovens
Jun 02, 2009 | Whirlpool GSW9800PW Washer
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool GSW9800PW Washer Logo
1,380 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
