Question about Whirlpool LSR9434PQ Top Load Washer
Water leaking LSR943pq0 washing machine leaking water even with washer off and water inlet hoses turned off
  • 30 Answers
Check the fill hoses to check for tightnes, also check the other: Washer in the fill hose end, facult connection, drain hose in drain, drain pluged. If none of these, call a appliance repairman for help if cannot solve the other yourself. Hope this might help.
Posted on Jun 02, 2009
Washing machine is not working and showing error H20
An H20 error means there is a problem with the inlet water. If could mean that there is no or limited incoming water pressure. If could be a problem with the inlet valves. It could even be a problem with the pressure sensor that detects how fast the washer fills.
First is any water entering the machine? Check if the shut-off valves are open. Check your washer hoses and replace them; some anti-burst hoses will restrict the water flow when they detect a leak. Take off the hoses with the shut-off valves closed. Then open the valves and let the water run into a bucket to check the water flow. Turn off the valves after confirming good water pressure at the appliance.
Check the filters in the washer inlet and where the hoses connect to the shut-off valves. Clean the filters. If you still have no water entering the machine, replace the inlet valve. It has probably failed in the closed position.
If you do have the washer filling in a short amount of time (8 minutes), then the pressure switch, the air hose is dirty or leaking or the reed that detects the flow speed could be faulty. The air hose can be checked by blowing through it. If you put a volt meter across the pressure switch/reed when you blow through it, you can rule out a problem with those items.
I hope this helps. Please add a comment with the make/model of your machine for extra details on the error.
Sep 05, 2015 | Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
My lg wm0742hga front load washer machine over fill of water causing to leak out from the door
even when overflowing it shouldnt leak from the door? less u have a bad door seal? the water problem may be due to a bad water inlet valve? have u notice water in the tub even when ur not using it? check with a multimeter the inlet valve and the water pressure switch? blow into the water pressure switch while it is in the wash mode filling with water and if it starts washing the diaphfram is good if not its faulty. u can also checl the water inlet valve the one with the hoses attached . by running either a hot or cold cycle only and turn off the hot then turn off the cold? see if it continues to over flow with each cycle? hot then cold- GOOD LUCKKKKK
Dec 04, 2014 | LG WM0742HGA Front-Load Steam Washer with...
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
Why is my machine flashing a tap sign and stopping?
Hi and welcome to FixYa, I am Kelly.
Turn off the water at the wall connection and remove the water hoses from the inlet water valve. Remove the inlet screens and wash them under slowly running water by rubbing your fingers over them. Reinstall the inlet screens and re-connect the water hoses to the machine. Remove the hoses at the wall connection and make sure the installer has not installed inlet screens on the hoses. If there are inlet screens on the hoses also clean the inlet screens. Then reconnect the hoses.. turn on the water and test for leaks then test the machine.
This should get you going unless you have relly low water pressure in the home.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Hotpoint WMA74 Front Load Washer
Water continues to run into the washing machine through the whole wash cycle and even when the machine is off. I have to keep the tape turned off. other than that the washing machine functions normally.
Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
- First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
(Use a knife blade on the outer part of the screens to remove them from the water valve)
- Connect both hoses to the water inlet valve without the inlet screens.
- Connect ONE hose to the wall faucet
- Place ONE hose in a bucket
SELECT WARM WASH and start wash fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
Stop Fill
Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
START warm fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
STOP FILL
- Connect hose to wall connection
- WASH the inlet screens under slowly running water until both sides are clean
- Remove hoses from the water inlet valve and install the inlet screens.
- Reconnect hoses and turn on water supply
TEST HOT and COLD fill
Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
Thanks for Choosing FixYa,
Kelly
Dec 17, 2010 | Washing Machines
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Whirlpool LSR9434PQ Top Load Washer Logo
163 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
