Question about Dell Inspiron 1501 Notebook
Dell Inspiron 1501 LCD flashing colors,works fine on external
Dell Inspiron 1501 goes through every color in the spectrum on startup,never gets to a ledgible screen.Works fine on an external monitor.
Im guessing that it could be an inverter issue,or possibly the entire LCD,but would like confirmation so I know exactly how much cash to spend(hoping its the inverter)
  • 197 Answers
Have you updated the video driver?
If yes but problem persist I suspected it's your LCD screen is faulty and needs to be replace.
If your machine is under warrantly no need to pay any fee for the replacement of the part.
Posted on Jun 02, 2009
My video on dell inspiron 1501 flashes on and off on the screen, Hooked up external monitor and it works fine. What do I need to look at
Try reseating the video cable and ensure the cable is chafed where is passes thru the hinge assembly. If no change, then the LCD will likely need replacement
Jul 27, 2010 | Dell Inspiron 1501 Notebook
I have a dell inspiron 1501.its lcd display not working
Hi there!
You can try a few things to check if there is something
wrong with the hardware of the computer.
First, try to update the video driver and also the BIOS
which you can get from the support website of DELL.
If the same problem persist try to run the LCD test .
While the computer is off press d+power the test should run and if it is an LCD problem, the display will either be blank or distorted.
Or if you will be able to re seat the cable connector
of the LCD that can be a good thing to try.
Hope this helps!
May 30, 2010 | Dell (002TR) Motherboard
Pink flashing band down the middle of the screen
Hi:
You most likely have a bad LCD panel on your laptop, and to verify that is the problem, connect up a desktop monitor to the external VGA connector, and toggle to the external display. If it has a good display on the external monitor, you have a bad LCD panel. If the color band is still showing up on another monitor, you have big problems!
Mar 24, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
I've got a Dell Inspiron 1525. When I power on the unit, the LCD shows the Dell startup screen, then a whinning noise and the screen goes black. Sometime shortly there after the Windows screen appears but...
This sounds more like a hardware issue. Now you say that the external display output is working fine. It could possibly be a problem with the lcd display itself shorting out. If there was a problem with the video hardware then I do not think you would be able to get the external display working either. The whinning noise could be coming from the lcd inverter.
Dec 14, 2009 | Dell Inspiron 1525 Notebook
Blank Screen. Dell Inspiron 1501 ¿?
#1 Tighten the screws for the Display Hinges (The LCD grounds through the hinges)
#2 reseat the display connector to MB
#3 replace display
Sep 14, 2009 | Dell InspironTM 1501 Notebook
My dell inspiron 1501 laptop has been flickeri ng colors or a lrge strip down middle , now half the screen is black with little color line
hello
This could be anything from the screen is dying or the inverter (electronic board that powers the screen' back light).
If you press slightly at the top of the screen, see if the lines will disappear or not, if it does then come back again; you might need to change your lcd.
hope it helped
TekSpotDotCoDotUK
Aug 26, 2009 | Dell Inspiron 1501 Notebook
Replaced LCD Inverter, now screen comes on and bright but choppy
Does the external monitor display a normal image?
If the images is OK then the video card is OK.
The inverter supplies high voltage to the CCFL lamp which provides the backlighing and does not jumble the colors on the screen. If you get a pinkish hue or a flashing screen then this would indicate
the CCFL lamp is faulty.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Jul 19, 2009 | Dell Inspiron 6400 Notebook
Dell Laptop E1705 Screen goes Blank
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is have the LCD panel replaced. The ribbon cable that plugs the LCD panel into the motherboard could also be the culprit. Here's a link to the display assembly for 1501: http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Jan 09, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
539 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
