Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
INSTALLISATION OF XP IN PEN DRIVE
HOW CAN I INSTALL XP IN MY 4 GB PEN DRIVE, WHILE THERE IS AN OTHER XP IN MY HARD DISK
  • dibyajyotimo Jun 02, 2009
    PLEASE SEND THE ANSWER OF MY QUESTION AS EARLY AS POSSIBLE
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Hmm... Well you can use Damon tools (http://www.daemon-tools.cc/eng/downloads) to make an ISO of the XP disc, but after you shut down your comp half way through your instalation, I don't think that Damon tools can mount a disc under bios (the part of your computer that runs without the operating system like Wondows or mac). In that case, I'd search around the internet.\
And I DID! This is what I found: http://www.eeeguides.com/2007/11/installing-windows-xp-from-usb-thumb.html
Please rate :)
Posted on Jun 02, 2009
My hpv165w 4 gb pendrive shows empety
Format the usb key with HP USB Disk Format Tool.
Then download Universal USB Installer (Pendrive Linux) which has support for booting/installing Windows Vista, 7, and 8
Mar 29, 2013 | PNY HP P-FD4GBHP165-EF BLUE HPV165W USB...
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
Windows xp does not install
If your hard disk is a SATA disk then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 23, 2013 | AMD Phenom II X2 Processor 560 (3.3 GHz)...
Hi I have a Fujitsu Mobile MHV2120BH 120 GB SATA Hard Drive, I want to install XP home on it. But Ive been reading that I need Sata/raid drivers for the computer to see the drive. I have a HP Pavilion...
The SATA drivers will be on the XP disk. Just put the XP disk in your CD drive, partition the new disk and load the OS.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 16, 2010 | Fujitsu Mobile MHV2120BH 120 GB SATA Hard...
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
Aug 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My pen drive is not formating in xp window
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Jun 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
BIOS settings to boot from pen drive
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Apr 03, 2010 | Computers & Internet
I HAVE A COMPACQ PRESARIO CQ40 108TU WHICH HAS INTEL DUAL CORE 2.0GH, 1 GB RAM,AND SAMSUNG 150 HARD DISK. I CAN INSTALL WINDOW VISTA BASIC, WINDOW 7, WHICH I HAVE ALREADY TRY. BUT WHEN I TRY TO INSTALL XP...
what happen is this once you see such again change the Operating CD you are using and get another XP CD to try it again it might be the fault of the CD but if it persist then find a system that you will us it to format your harddisk and load the operating CD then later you change it back and ready for use
Feb 20, 2010 | Compaq Presario Notebook
To use moserbare 1gb pen drive
sarwesh,
to use USB mass storage in Windows 98 you need to install drivers for your mass device. So,
  1. Findout if any CD/DVD shipped with your pendrive. Install driver from that to your Windows 98 PC, then you can use it.
  2. If you don't have any setup disk from manufacturer, there might be drivers and software prestored in your pen drive. Use this pendrive to any other PC with XP/Vista. Burn these files to any CD/DVD and then make install these drivers to your Windows 98 PC, after that you can use your pen drive on your Windows 98 PC.
  3. If you are not able to do step 2, then goto manufacturer's site select your model no. and download driver and install.
If still you didn't found. Tell me your pendrive manufacturer and model no. I will try to give you link.
Thanks
Iqbal
Apr 09, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
