Question about Dell E153FP 15" LCD Monitor
Monitor goes dark after a few seconds from power-up
Ater a few seconds from power-up, the screen goes dark - Green light is on - If you shine a light on the screen you can barely see the display - If you power off and on, the screen works again, then goes off I opened the monitor, pulled out the lamps to measure them (to order replacements), put it back together, and it now works fine. Any suggestions on why that may be so? In the next post, I'll describe the process. ok I have a monitor dell & him have a lock in the screen and power is up boot the screen ged dark
El Duderino
  • 47 Answers
SOURCE: Monitor goes blank
Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Posted on Nov 16, 2006
El Duderino
  • 47 Answers
SOURCE: Monitor goes blank less than a second after turning on.
Hi Abbie, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Posted on Nov 26, 2006
  • 5 Answers
SOURCE: E153FP Monitor screen goes black light is green
The capacitors are probably bad. It is a common problem and easily fixed by taking it apart and replacing the capacitors. Try to find Rubycon Capacitors because they very rarely go bad. Do a search on google for bad caps. I have fixed about 30 monitors this way. Dell is a company well known for bad capacitors. It may not be your problem but replacing the capacitors should cost less than $10 if you do it yourself. www.photphot.com
Posted on May 15, 2007
  • 14 Answers
SOURCE: Dell 1800FP Dark, No Power but power supply seems fine. Help!
I just repaired 3 1800FP's - all dead, no lights.
Firstly a dead 2AS01 is 95% of the problem, because some fool designer left out the protective zener diode - cheapness.
Mouser Electronics does not have this part, but lists it at 37 cents in lots of 2500, and gettable at $2.66 somewhere else.
You must also replace the two small value electrolytics near this IC, as some had an ESR of 40 where <0.5 is where it should be.
I suppose as the electro's dry out, the spikes can zap the IC. The quacks on ebay flogging 2sa01's alone, probably hope to sell you another one down the track (at a fat markup).
There are 2 'Sam Young 2200uf' electros that really should be replaced, with ESR or 2-30 ! Ideally replace ALL electros, as the others will be off - but those 4 as a minimum and using a jewelers loupe, resolder other joints on the transformer and anything that looks more dull silverish, than the rest. A 1 inch used and worn paint scraper will get the case open easy.
DANGER, CAUTION : Finally when refitting the inverter board, ensure the steel tab is over the TOP middle of the board facing away from the power socket (SO YOU CAN SEE IT) . The board sides in flat. It is possible to scew the board down with a slight bend, with the tab pressing over the pcb tracks - very , very bad!
Now all I need is for some kind soul to improve the fix by stating what the value of the missing zener should be.
PS. Just because the caps are not bulging does not mean they should be OK. Most wrecked 10 year old power supplies have better ESR's, so the electronics must be hot under the cover.
I have seen bulging caps with a GOOD ESR, and non bulging ones with an ESR of 47.
Canberra
Posted on Aug 28, 2008
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ aol.com. Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Robert
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
Screeen comes on --then goes blank
Your inverter circuit is faulty. This controls the lights inside the screen so you can see what is happening on the LCD panel itself.
If you shine a torch into the LCD from the top at an angle you will still see the images on the screen. But with no light inside to project it outwards, it's dark.
A local TV repair shop should be able to do the reprair fairly cheap, but it's best to make a few phone calls and check they will work on an LCD monitor firstly, and secondly a rough quote.
This is a very common fault with LCD monitors.
Hope that helps =)
Apr 15, 2008 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Monitor displays breifly then goes to blank screen
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Screen black
Bill, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 06, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
615 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
