Question about Toshiba REGZA 47HL167 TV
Multi colored lines running from top of screen to bottom
I have A 52 inch Toshiba Regza LCD T.V. There are lines running from the top of the screen to the bottom of the screen. The colors that show the most are pink and blue and it is only on the right side of the screen. The T.V. is two years old. Any suggestions for repairs/ parts I would need to buy to fix this? Thank You!!
  • plynjhon Jun 02, 2009
    Thanks for your comment. The t.v has not been dropped or damaged in any way. The lines appeared while watching t.v.. could it be something else. Maybe in inverter or some other board troubles? Thank You...
    Top Expert:
  • Toshiba Master
  • 75,417 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Jan 17, 2017
  • 643 Answers
Panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
Posted on Jun 02, 2009
  • Frank McDONOUGH Jun 14, 2012
    If the lines do not affect the menu,it's the T-con board.If the lines go through the menu,then it's the panel
My 52" Toshiba Regza has a six inch vertical line just left of center that changes color as the picture changes. Some times it stays with the same pattern for quite a while. It goes away when I turn it off...
you must either change the t- con board, or the left board strip. it is dangerous because mines caught on fire. but most like since that strip is connected to the lcd screen u will have to replace the whole entire screen.
Aug 09, 2010 | Toshiba REGZA 52RV530U LCD TV
I have a toshiba regza 52" lcd tv. After about 20min the left half of the screen develops lines from top to bottom and then freezes and turns red or green or blue or multi-colored but there is no visible...
Three possibilities: LCD panel TFT driver circuits, T-CON board, main board LVDS driver IC. I would get a can of cold spray fro electronics troubleshooting and start cooling the ICs in the main board, T-CON board (you need to remove metal shield to get to the T-CON board to see if it is heat related problems.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 07, 2010 | Toshiba 42HP66 42 in. LCD Television
Toshiba regza 52xf550u has a 6 inch multi colored line in the middle of the screen...what is the problem
If it flickers and changes colors like my 52" did, I removed the back panel cover, tore off the cheap foil on top and removed the t-con board. Used a head gun as I seem to fix alot of things with it now adays since lead free solder is cheap, heat the points up for about 2 minutes, replace it and throw some air circulation. I also noticed the top of my lcd has two main boards the are supposed to match up a platic pin and slide into place, the boards were warped and wouldn't stay down. I used a dremel polishing wheel, cut it in half and wedged them down and tv is running clean again.
May 15, 2010 | Toshiba 52HL167 52 in. LCD HDTV
Getting colored vertical lines on the right 1/3 of my 52" Toshiba LCD why? can it be fixed?
looks like the lcd panel is damaged contact the toshiba service on your area
May 04, 2010 | Toshiba REGZA 52RV530U LCD TV
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Jan 19, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Toshiba REGZA 47HL167 TV Logo
1,179 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
