Question about Traxxas Rc Revo Nitro Monster Truck
Traxxxas Revo 3.3
I have a Traxxas Revo 3.3 and when I turn it on it works fine but when I use the brakes it always turns off, does anyone have an idea why???
please help :)
  • 3 Answers
You need to adjust your idle, what's happening is every time you apply your brakes you also close your carby throttle, your truck is not getting enough fuel because you have your idle set a fraction low. Simply turn or your electrics then take your air filter off, now adjust the screw under your carby until you have 1-2mm opening when you apply your brakes.
Posted on Jul 28, 2009
  • DogzBallz Jul 28, 2009
    Your idle screw is set too low, it's the screw underneath and directly in front of your carby You need to turn your electrics on take your air filter off and adjust the idle screw until you see a gap of 1-2mm inside your carby when you apply the brake.
  • 88 Answers
Throttle/brake linkage might need adjusted. Also with the air filter off, check to make sure that the idle screw is adjusted correctly. With the throttle at neutral there should be a slight opening in the carb.
Posted on Dec 24, 2009
Alignment on my traxxas
the one that turns left by itself has come loose from the turning servo, you must take the body off to look
Dec 27, 2012 | Traxxas E-revo E Revo Brushless Edition...
E-revo 1/8 scale manual
All manuals for Traxxas current model trucks can be found @
http://traxxas.com/support/PDF-Downloads-Current-Models
All manuals for Traxxas previous model trucks can be found @
http://traxxas.com/support/PDF-Downloads-Previous-Models
Hope this helps
Feb 23, 2012 | Traxxas Brushless E-revo 4wd Mamba Monster...
Traxxas revo 3.3 running problems
Maybe running to lean or to rich. When you accelerate put youre hand where the exhaust is and you should get a light spraying of unburnt fuel over hands(lovely!). If you do you may be able to screw in high end needle in a bit and i mean just a bit. If you hear the engine note raise a bit with a slightly higher pitch then you are running to lean and you will want to unscrew the high end needle valve asap.
Also check youre idle screw and make sure thats not closing the carb and stopping any airflow into engine. Let me know how it goes.
May 30, 2010 | Traxxas Rc Revo Nitro Monster Truck
Trouble startin , does not go full throttle and keeps stoppin.
First make sure you have about 1mm gap on carb opening and fine tune with trims. The high end needle can now be turned in about 1/4 of a turn and start. Keep trying to start while turning high end needle in a fraction in at a time, say after about 5 to 8 pulls of starter. Once engine is started come back out with screw a fraction to see if runs ok if not go back in.
May 18, 2010 | Traxxas T Maxx 3.3 Monster Truck
I have a traxxas revo 3.3 and it turns over but it will not start what do i do
The glow plug could be bad. If the motor turns over and is getting fuel I would replace the glow plug.
Jan 07, 2010 | Traxxas Rc Revo Nitro Monster Truck
Revo problems
try checking the auxillary fans if its working, replace it if its not. hope this helps
Jul 03, 2009 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Revo 3.3 shifting problem
you might need to reset the opti drive. turn the power on with the engine still off and hold down the optidrive button for 5 sec. see it that works.
Jun 24, 2009 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Rc Revo Nitro Monster Truck Logo
647 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
