No sound from speakers
My speakers were working ok and then they wernt any way to correct this problem I have a grandaughter she like book reading on the computer before bedtime also I have a internet business speakers are a essantial part of this computer. please help with this issue Thanks Marie
  • 147 Answers
SOURCE: The speakers don't work anymore...
TheLastStraw,
Pardon the pun, but it "sounds" like you need a new sound card. I recommend TigerDirect for quality parts, service, and shipping.
Please let me know if this helps. Good luck!
Posted on Feb 29, 2008
SOURCE: Speakers not working correctly
you need to activate speaker fill i the settings
Posted on Jun 19, 2008
vanbiaka
  • 104 Answers
SOURCE: computer speaker problem
Make sure the cable connected to INPUT directly connected to your sound card on GREEN plugin
Best Luck!
Posted on Dec 06, 2008
mgroomsn002
  • 76 Answers
SOURCE: since I have windows vista, my logitech speakers
need to download audio drivers from manufacturers website for your computer and that should take care of the problem
Posted on Jul 05, 2009
SOURCE: Green light on speakers and sub. No sound - only hissing noise
It may appear that the output from the computer is not connected to the input to the Altec Lansings. The correct color is Green for output to speakers line level. Blue is input from mixer or other possibilities Line level. Pink is Microphone (Mono). If this doesn't assist sometimes the front panel will override the rear panel outputs. Good luck.
Posted on Sep 17, 2009
I need to know the speaker wire colors for a 1994 toyota 4runner limited
According to the book it is: right speaker-1 light green with black 2 blue with red 3 light green with black 4 blue with black...left speaker:1 light green with blue 2 light greeen 3 light green with yellow. This out the book, if you dont under stand because wiring diagrams are hard to read, get back to me and i'll see if i can send you a picture of it ok.
Aug 20, 2011 | 1994 Toyota 4Runner
Hi Thanks for your help, One year old Sony mini
sir i think ypur unit is ok and run correctly... try to check your speaker maybe your speaker got open or burnt... you can test it by swapping your speaker to another unit or you can test your speaker using multitester...just point your selector at resistance test a speaker has 8ohms reading....
the speaker has a two terminal.. a positive terminal and a negative terminal... your multitester has a two lead.. red lead which is a positive and a black lead which is negative..
measure-speaker-impedance-1.1-800x800.jpg Multimeter probe sockets (NL Graphics) Insert the probes of a digital multimeter in the correct sockets of the multimeter. There may be several different sockets for the probes depending on what parameters you're measuring. Look for the sockets marked "impedance" or displaying the ohm symbol. Different models and brands of multimeters will vary in their labeling, so check your multimeter's manual if you're not certain about which one to use.
  • 2 Select the range for the multimeter. Since you'll be measuring fairly low resistance levels with a speaker, choose a range that will encompass readings in the 2-16 ohm range. It's extremely rare to find speakers that will have an impedance outside of that range.
  • 3 Touch one probe to each of the speaker terminals and check the reading. This will be the impedance of the speaker. Record the measurement, and when you're done, turn off the multimeter to preserve the batteries for the next time you need the multimeter.
  • Read more: How to Measure Speaker Impedance ' eHow.com http://www.ehow.com/how_5068180_measure-speaker-impedance.html#ixzz1OsNOPSq3
    if you think this help please rate me thanks...
    Jun 10, 2011 | Sony CMT-HPZ9 Shelf System
    Center speaker does not have sound
    First double check all connections. And if that does not fix pull the cables on one of the working speakers and plug into the center speaker to make sure it is not a bad speaker. If the speaker works connect them back the way they were and Click Start then open Control Panel look for Sounds and Audio Devices click on it. It should open to Volume now down on the bottom you will see Speaker settings click on Advanced. Speaker Advanced Audio Properties should open look for Speaker setup click on the little blue V, go down and click on Surround sound speakers now click Apply then OK and OK again. It should work correctly now.
    Thanks for choosing FixYa, If you find this helpful please vote and leave a comment.
    Oct 14, 2010 | Logitech X-530 Computer Speakers
    The sound only comes out of 2 speakers - (shows only 2 speakers on display). When the display shows all 5 speakers, we dont get any sound at all. Can you help
    Aside from connecting the black wires and the red wires in their correct places, if you have a blown speaker in the center or surround, it will cause the others not to work.
    Here are something things to look for:
    1 not every wire is suitable. Most wires are ok, but have natural resistance that prevents some of the signal from reaching the speaker. (impedance, measured in OHMS.)
    2. Most of the newer systems have rca or banana connectors to insure clean interfaces.
    The reviews I read on this product do not inspire me to go out and buy one, so if you can still choose something else consider it sooner rather than later.
    3 the amplifier for the surround sound speakers may already be damage
    Try every speaker on the output that works. That way you can tell if the speakers are the problem or if it is the amplifier.
    Good luck.
    Sep 26, 2010 | Panasonic SC-HT900 System
    Ok so my speakers are not working. the green light is on but no sound comes out and i know its pluged in right
    try another speaker. if OK. the problem is on Dell A215 Computer Speakers. if other speaker don't work.
    Check your soundcard. reinstall the driver. and make sure the driver is install correctly.
    Aug 25, 2010 | Dell A215 Computer Speakers
    Sherwood RX-5502 receiver - get no sound.. checked polarity - OK... replaced speaker wire - OK... checked speakers on another device - OK.... tried phono and tuner and cd player - no sound with any........
    After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
    There may aIso incorrect selection of the input source. Select the correct input source.
    If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
    Thanks for using Fixya.
    Jul 11, 2010 | Sherwood RX-5502 Receiver
    Radio works. volume problems on drivers side front speaker
    It sounds like the problem is with the speaker, not with the radio
    Dec 04, 2009 | Cell Phones
    Speakers dont work
    THE PROBLEM is that being in atruck the vibration are greater and things move in time and as this has hapend its quite possible its shorted on the speakers and blow the audio chip so if that is the case just buy an amp and conect that and fix the problem a lot cheaper
    Oct 25, 2008 | JVC AM FM CD DET FACE CAR STEREO
    Only one speaker works
    if you have plugged correctly without any losse contact it should work if not o think your speaker configration is not correctly set go to the control panel->sounds and audio devices->device volume->advanced there u set that balance slider to middle of all volume control,wave,sw synth,line in etc.. then go to speaker settings in the same window of sounds and audio drivers there in speaker settings click on advanced you get another window in that drop down box specify your speaker configration wether is desktop speakers laptop mono speakers or stereo headphones etc specify the right one you have then ok after this in speaker settings click on speaker volume and keep left and right speakers to maximum then apply ok this will work check it out if stil not worked tell me what ws the result ill solve that for u
    May 07, 2008 | Cyber Acoustics CA-3550 Computer Speakers
    32 people viewed this question
     Grubhead
    Grubhead
