Camera works fine if flash is not needed. Try to use the flash right away get few strobe flashes and the busy flash sign pops up goes away try again same result eventually the dreaded err 99 message comes up. I have tried power off/on re-installing battery, and cleaning lens contacts. Nothing works just wondering if i now have a camera paperweight.
Per the problem description, it seems the flash circuitry has a malfunction.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing tgo open it and perform some basic diagnostics of the failure. You will need tools to do it, which includes the usage of a soldering iron.
I'm getting an error msg sayign shooting is not possible and to utn power switch to on and off again...
(More)
I'm getting an error msg sayign shooting is not possible and to utn power switch to on and off again and to re-install the battery, I think some moisture may have affected the machine, what can I do to solve this? Many thanks in advance Rachel
I have a canon eos rebelxt. 3 pins were bent in memory slot. I tried to straighten them and they...
(More)
I have a canon eos rebelxt. 3 pins were bent in memory slot. I tried to straighten them and they fell out. My camera still works and uploads the pictures. Can I expect to see some problems somewhere? So far nothing bad has happened.
I have downloaded pictures from camera before, but now get an error message saying ''camera not...
(More)
I have downloaded pictures from camera before, but now get an error message saying ''camera not recognized''. Have tried reloaded EOS utility, but that doesn't seem to work ( not asked to indicate what camera I have). I have an EOS Rebel XTi.
my flash worked fine yesterday but now whenever I try to take a picture the in built flash pops out...
(More)
my flash worked fine yesterday but now whenever I try to take a picture the in built flash pops out but does not work! Can anyone tell my whats the problem?
