Question about Starrett T216XRL-1 - MICROMETER, DIGITAL
No 734 starrett
On fitting a new renata battery, the display shows all figures...how do you clear?
2 Suggested Answers
SOURCE: I just aquired a Starrett 721 digital caliper that
More than likely. But to make sure: check that new battery is good (voltmeter). Check with ohmmeter across the battery contacts - should read few hundred ohms to few kiloohms. If OK, reinseret battery. Push ON button. Push reset button. If go, congrats. If not, get another caliper.
Posted on Dec 07, 2009
Starrett no 731
Are you certain the battery is installed correctly? Many electronics won't work if the battery is installed backward/upside down. Do not ask how I know this....[-:
Jan 15, 2014 | Cars & Trucks
Shut down starrett 733
On some Starrett calipers, there is no way of turnig them off, which means about once a year you have to replace the battery. sorry
Jan 22, 2013 | Starrett Electronic Caliper
How do you set a 722 starrett digital caliper to zero.
Just ran into the same problem. Bought a caliper at a garage sale and it needed new batteries. When i put them in it was reading .006. I held the M button down for 2 seconds and it reset to .000
Jun 16, 2012 | Starrett Electronic Caliper
Starrett 721 6 inch Caliper
you might have some crud between the coded strip and the reader behind the display, or a chip trapped some where. try cleaning all the parts you can get to it with an alcohol prep pad. As a last resort Starrett will refurbish it for you. it isn't that cheap but it will be less than a new one. give them a call.
Jan 31, 2010 | Measuring Tools & Sensors
I have a Starrett 749 micrometer that will not power up I replaced the battery but still nothing
I have a Sterrett 733XFL-1 (O-1" Digital Mic). It turns out that these will only use the Renata Batteries. (Radio Shack Batteries are Renata and some Battery Stores Carry Them). The Renata CR2450 has a smaller diameter negative terminal (smaller diamter back half of battery). If you use an engergizer or other, the battery cover will short against the positive battery terminal and the tool will not work (and the battery will quickly drain being shorted to case)
Dec 16, 2009 | Starrett Measuring Tools & Sensors
I just aquired a Starrett 721 digital caliper that wouldn't turn on. Took cover off and batteries were in reversed polarity. New batteries didn't help. Is the display fried?
Dec 07, 2009 | Starrett Electronic Caliper
Watch still not working with a new Renata CR1225 Lithium Battey
while battery on its place touch the 1 End with battery and secound with AC small Gold dot
from
AmFix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 13, 2009 | Casio W94HF-3AV Wrist Watch
Need replacement battery for the above
I had the same problem. My jeweler came up with a solution. He "dibbled" the rear of the case just enough that the next smaller Renata battery would fit. You can't tell that he did anything but it worked. Hope this helps.
Apr 21, 2009 | Watches
Starret 734 Caliper will not power up
OK, I fixed it! After hearing back from Starrett, it seems that a RENATA battery is the only one that fits right. I went out to Radio Shack and checked their stock, which turns out to be manufactured by RENATA. The new battey works fine... It did take a try or two to get the display cleared, then Error04, now it's working again.
--David--
Mar 25, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Starrett T216XRL-1 - MICROMETER, DIGITAL Logo
351 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
Vernon Taylor
ray gallant
Vuk B
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
