Question about Broan-NuTone N-QT140L Combination Light Fan Exhaust Fan
Trying to remove service grill for Nutone QT140L combo fan/light
The service grill has not been removed for 10 years and I need to remove it to replace the light and clean the grill. I checked the manual and it does not show the grill. The grill has two vents on the left and right side of a plastic light shield. There are two tabs with arrows to push towards the light shield to release the grill. The grill is releasing slightly on the side near the tabs. Do I need to apply more force to release the grill? Is the grill just one piece?
    President:
  • 272 Answers
Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
Posted on Jun 02, 2009
    President:
  • 1,902 Answers
You need to apply more force they kinda get stuck after awhile. The gril should be only one piece
20 yrs old nutone fan light it only pulls down about inch i need to change buld
There are spring clips that hold the grille in place. The clips can be compressed and detached to permit complete removal to gain access
Feb 08, 2013 | Broan-NuTone Broan 110 CFM Premium Bath...
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
Fan is making ratteling noise.
pull off cover and check fan for a loose bearing. "will wobble if it has a loose bearing". if not a bad bearing then tap on moptor housing while on and be careful not to touch a fan blade. then replace cover in reverse. :)
Sep 21, 2010 | Broan-NuTone N-QT140L Combination Light...
How do I remove the light from the ceiling?
Sent you a question on this but did not receive a reply.
If you are talking about removing the grill/globe to change bulbs, it just pulls down from the ceiling. There is a heavy "V" spring on each side that needs to be compressed to pull the grill/globe down. Once it is down as far as it will go, the springs need to be squeezed together and the ends removed from the metal box in order to take the grill/globe off. It is not necessary to remove the grill/screen completely to change bulbs.
Please see my other message.
Paul
Sep 18, 2010 | Broan-NuTone N-8663RP Combination Light...
We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
How do I remove the cover
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
May 10, 2010 | Broan-NuTone N-8663RP Combination Light...
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
Nutone 665RP fan/light/heater all not working
Hunt for a tripped GFCI and push reset. The ground fault protected receptacle may be in a nearby bedroom, hall, or basement.
Dec 06, 2009 | Broan-NuTone N-668RP Combination Light Fan...
Broan nutone 721
If you remove the the lens there should be a model number online. There are several places online that sells parts. The 721 is a Broan part if yours says Nutone then you will need to try to find that model number.
www.nutone.com
https://www.centralvacuumstores.com/fan_help.php
www.rinutonedistr.com
Feb 17, 2009 | Broan-NuTone Designer 721 Ceiling Fan
Broan-NuTone N-QT140L Combination Light Fan Exhaust Fan Logo
512 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
