Question about Syntax Olevia 537H Television
TV does not appear to be powered. Either fuse or power supply
The power supply FSP271-4F01 is bad. It has a couple bad parts. Are schematics available? Or a used or new power supply or replacment part # available. My seach on the internet did not show anything in stock. I ran into the same problem on my LT42HVI. It just died today 6/1/09. Where is the fuse located or is this a lost cause? gdsos
    Problem Solver:
The fuse is in the power supply. It's a slow blow fuse rated 250V 5A.
Posted on Aug 20, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: Bad power supply Olevia LT42HVI 42"
If it is a power supply issue go directly to the Manufacturer FSP USA. Get in contact with the RMA department and for about $20 dollars plus shipping one way you can get your PSU fixed. Turn around time is about 3 to 4 weeks so be patient. Once fixed they send you an e-mail with tracking info. I did this an probably saved hundreds of dollars. The removal of the PSU from the TV is pretty straight forward, 4 connectors and just a bunch of screws. Keep track of the screws and where they go also take a pic of how everything was connected to you can reference to put it back together. One warning stay away from a company called Discount Merchant to try and buy a new PSU the sell refurbished junk that does not work. I tried buying from them a replacement PSU that was DOA and they did not want to refund my money and it was a huge hassle and I had to involve the BBB and my CC company to get a refund. Save yourself the nightmare and go through the Manufacturer. Below is the email contact info incase you cannot find the website.
FSP USA RMA Services" <rma@fspgroupusa.com
Bizznyc.
Posted on Jun 07, 2010
Samsung LN40B500P3FXZA TV has no power. Replaced bad 3.1A fuse but it blew again when attempting to power on. No obvious bad components (blown capacitors). 6.3A fuse is still good.
Since that I have not schematic diagram of your tv... I cannot figured you out the exact part number of those components that caused the problem, but the possible reason why the fuse are always blown when you turned on the unit? because there are some bad filter capacitor, rectifier diodes and power IC regulator in primary power circuit section.
Nov 08, 2016 | Samsung Televison & Video
Repair or Junk my Samsung UN55C6500VF TV?
Hi William,
Not necessary to junk your TV. Damages due to lightning are extensive at times but from what you have mentioned it appears that may be it is only the power supply board which has gone bad and rest of the TV is ok. Replacing power board may restore your TV.
Good Luck.
Aug 24, 2015 | Samsung Televison & Video
NO POWER. CORD TESTED OK AND IVE ALREADY CHANGED THE FUSE BUT STILL NO POWER...
Why did you change the fuse? If it was blown, then power supply has failed. Here is your schematic. The power supply is on page 14.
http://elektrotanya.com/behringer_ub-2222fx-pro.pdf/download.html
Scroll down the page at the site to the "Get Manual" Click on that to download the schematic. When working on line operated supplies use an isolation transformer for personal safety. The regulator chip IC2 has probably failed but test before changing. HINT: When restoring the supply, put a 60 watt light bulb in series with the hot power lead to act as a resetable fuse... saves fuses and also other components if all the bad parts haven't been weeded out.
May 11, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
TV blew fuse. Replaced with 125v 5 amp from a 33 inch Toshiba that has gone bad. The 5 amp also blew. Purchased new 4 amp fast blow fuse for unit, now nothing happens, i.e., no blown fuse, no circuit...
replacing the fuses with random values is prolly not a good thing...but one thing to check is a big transistor know as the HOT. This will more than likely be clipped or screwed to a heat sink NEAR the flyback (big transformer, has a wire going into the big glass tube). That causes fuses to blow...If this does not work, let me know.
Nov 30, 2010 | Toshiba 13A23 13" TV
My lg tv wont turn on.
First, I would try leaving the TV unplugged for an hour so the TV can discharge and reset itself.
If this doesn't work, it maybe something simple like a blown fuses inside the TV that needs replacing.Radio Shack or some electronic store will carry the fuses.
If the other two ideas doesn't solve it, we're talking about a power supply board related problem. I can't actually look at your TV over the internet. But, the most common problem with flat panel TV are the power supply board for the screen itself and the main power supply board for the rest of the TV. Commonly a bad capacitor or transformer will be on the board.
If you have some electronic experience and want to repair it yourself, you can sometimes find a Service Manual for your TV over the internet. Normally, costs less than $20. It will have diagrams, schematics, and part number list for the TV.
Sep 09, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
I have no power light. I hit the power button and
If this doesn't work, it maybe something simple like a blown fuses inside the TV that needs replacing. Radio Shack or some electronic store will carry the fuses.
If the other two ideas doesn't solve it, we're talking about a power supply board related problem. I can actually look at your TV over the internet. But, the most common problem with flat panel TVs are the power supply board for the screen itself and the main power supply board for the rest of the TV. Commonly a bad capacitor or transformer will be on the board.
Aug 09, 2009 | Philips Magnavox 42MF521D/37 Television
POWER SUPPLY BAD, NEED SCHEMATIC DIAGRAM COMPONENT LEVEL
Polaroid will not release component schematics not even to service centers as they are designed to replace the entire modules while under warranty out of warranty there is very little Chance of obtaining new replacement parts. As i have a 2006 LCD and a 2007 Plasma Polaroids and polaroid told me they are considered a disposable TV replacement parts are not available and suggested that I try ebay
Apr 29, 2009 | Televison & Video
Main power light turns on but i have no picture or sound
Take a closer look at the power board fuses. There is a fuse numbered 106 a little ways away from the rest of them. I have this same model and got it working long enough to diagnose a bad flyback transformer by replacing this fuse with one from Radio Shack. At some times, I could put in a new fuse and have the set work for a few weeks. The flyback transformer is available from parts.pioneerelectronics.com for around $60.
Jan 29, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
No power to tv
Hello Olsol,
This is an indication of a problem in the power supply. This problem can be in the switching power supply or in the high voltage power supply in either case there is some overcurrent or overvoltage condition which is cuasing the issue. Look for blown fuses and replace them, once this is done power on the set. If this works then great, but if not look at what is happening prior to the fuse blowing. Then using the schematic and a voltmeter attempt to find the shorted or open components by the lack of proper voltage readings. However if you do not have a background in electronics, I would suggest that call a TV repair shop and have this TV repaired.
I hope this helps,
Thank you,
Shuttle83
Oct 18, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Syntax Olevia 537H Television Logo
743 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
