Question about Air Tools & Compressors
Process oil accumlation on the last stages of a centrifugal Comp.
We have 8 stages mitsubishi centrifugal compressor. The oil level rises with the increase in the stage. The impellers are in the same direction they are not back to back. The section and the discharge are from the top of the compressor. Our question is , why the oil appears mostly in the last stages?
  • 41 Answers
The last stage works in very high temp, so it depends of which brand of oil you are using,because mineral oil evaporate in high temp
Posted on Sep 28, 2009
  • 58 Answers
Hi when the compressor is not running the levels should/must be the same when it is running the stages push the levels up in the last stages hope this helps merlin v12
Posted on Aug 19, 2009
  • chris doughty Aug 19, 2009
    hi when the compressor is not running the levels should/must be the same when it is running the stages push the levels up in the last stages hope this helps merlin v12
Air compressor won't start
does the motor just buzz when you switch it on? if so renew the start caacitor
Mar 09, 2014 | Mi T M Mi-T-M AC1-PE15-20M Electric...
The oil pressure is low at idle and rises with higher engine revs. Oil levels are ok, new oil approx 2000kms ago. Was a slight noise at one stage in the engine but went away after engine's revs in
It sounds as if the clearance that the bearings normally run in have been surpassed and need to be replaced. Higher engine revs will supply extra oil which will overcome any small discrepencies but constant running at this stage will result in faster degradation of all engine components concerned resulting in a more expensive repair. Shes basically worn out.
Feb 27, 2012 | 1993 Toyota Land Cruiser
Wont turn over
did u check oil level in pump end take belt off and try 2 turn pulley iff no go pump is seized pull off head and see iff ring is broke
Jul 31, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
A/c compressor lock up and leaking oil from the rear of the a/c comp. not cooling well unless driving at 1500-200 rpms.
If compressor is leaking,so is the refrigerant. A new , used,or rebuilt would be your oly option at this stage. Sorry.
May 25, 2010 | 2004 GMC Yukon
Compressor not cycling and building pressure after servicing
Hi
I suspect you may have either overfilled the sump or used the wrong viscosity oil, may have splashed up onto valves and patially jammed one open.
Aug 11, 2009 | Champion International Champion 532 2...
Temperature rising
Make sure that your pully fan is blowing across ehe fins. Check and clean the air intake filter. Check the oil level.
Regards, --W/D--
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Replacing Nissan Quest AC
orifice tube is in the high pressure liquid line going into evaporator. You will see a small crimp in the line.
go here for files & pics.
http://groups.yahoo.com/group/villagerquest/
Jul 03, 2009 | 1999 Nissan Quest
Temperature rise of compressor
check oil level may need oil and filter change radiator could also be dirty they clog up after awhile should be washed out with a hose often
Mar 18, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Air Tools & Compressors Logo
110 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
