Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Drum will not turn
Dryer powers on & sensor light stays on but the drum will not turn
    President:
  • 1,902 Answers
Check three things.
First off is that the brake is disengaging and is not holding the drum in place.
Next check the motor to make sure that it is not frozen.
Last but should be done first is look at the belt to make sure that it is not broken or has come loose
Posted on Jun 02, 2009
Dryer drum not turning
The belt should also be running threw a small pulley beneath the the drum. If it has come off of that pulley the drum will not spin.
Nov 09, 2012 | Dryers
Westinghouse dryer ld505e on/off button wont stay on when l push it
If it has dampness sensor strips inside the machine they may be coated with dryer sheet wax or some other mess. Clean them with windex and retry. As the clothes rub against these sensors the dampness causes the dryness board to keep the machine a going. if no dampness is detected the dryer shuts down. Supposely to save power.
Jun 18, 2012 | Westinghouse Dryers
The Hi and Lo gas valve coils do they work in tandem ? Does the Lo stays on all the time ? Ruy ...
Their is 2 coil hosing but one of them has 3 wires and 2 coils inside it. The ignitor does 2 jobs, it lights the fire and acts as a thermocouple through the holding coil. If the flame does not ignite after the sensor detects the heat from it and shuts down then once the ignitor cools down the gas valve is shut down even if power is going to the gas valve. When the temp drops below 105f in the drum the control closes contacts inside allowing power to be supplied to the gas assembly. The ignitor and flame sensor along with the booster holding and secondary coils are all energized at once but the solenoids won't open the valve because the ignitor is hogging the power. The power supplied to it runs through the flame sensor. When the temp inside the sensor reaches a point the bi-metal inside tripped the power to the ignitor and the power gets diverted over to the secondary coil. Thr flame stays on till the temp inside the drum reaches 160f at which time the control thermostat opens circuit to the gas assembly and power is shut down. The drum continues to tumble and when the temp drops once agin below 105 the process is repeated and another blast of heat is shot into the dryer. So what goes wrong? Faulty flame sensor sticking/open, cracked ignitor, old coils that work intermittently or not at all when hot but work again when cooled.themobilian_2866.jpgthemobilian_2865.jpg themobilian_2868.jpgMore here.
Aug 21, 2011 | Whirlpool GGW9878P Gas Dryer
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | LG DLG5988 Gas Dryer
Gas dryer 4 yrs young and won't heat. Drum turns.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 04, 2009 | Televison & Video
Dryer turns on, tumbles the drum but does not ignite the gas unit to heat and dry clothes
Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Sep 21, 2009 | Dryers
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
239 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
