Question about Acer Computers & Internet
Reformat windows vista from cd
What key do u press at startup of computer to reformat windows using recovery partition phillips mt6000 I am trying to reformat vista home basic from a cd, what key do I press to get to reformat screen?
    President:
  • 2,559 Answers
Click start,all programs,accessories,system tools,system restore,and choose factory settings when the window opens.
Or if you have the vista disk,put it in the cd drive restart and tap the F12 key while it is booting.
Posted on Jun 02, 2009
F11 will not put pc into recovery mode
To resolve this problem, use the following methods in the order in which they are presented.uparrow.gifBack to the topMethod 1: Repair the BCD store by using the Startup Repair optionYou can use the Startup Repair option in the Windows Recovery Environment to repair the BCD store. To do this, follow these steps:
  1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. In the System Recovery Options dialog box, click Startup Repair.
  7. Restart the computer.
uparrow.gifBack to the topMethod 2: Rebuild the BCD store by using the Bootrec.exe toolIf the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps:
  6. In the System Recovery Options dialog box, click Command Prompt.
  7. Type Bootrec /RebuildBcd, and then press ENTER.
    • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes. A confirmation message appears that indicates the entry was added successfully.
    • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.Bcdedit /export C:\BCD_Backupren c:\boot\bcd bcd.oldBootrec /rebuildbcd
  8. Restart the computer.
uparrow.gifBack to the topMethod 3: Rebuild the BCD store manually by using the Bcdedit.exe toolIf the previous method does not resolve the problem, you can rebuild the BCD store manually by using the Bcdedit.exe tool in the Windows Recovery Environment. To do this, follow these steps:
  7. Type the following command, and then press ENTER:cd /d Partition:\Windows\System32Note Partition represents the letter of the partition on which Windows Vista is installed. Typically, this is partition C.
  8. Type the following command, and then press ENTER:bcdedit /enum allIn the Windows Boot Loader section of the output from this command, note the GUID that is listed forresumeobject. You will use this GUID later.
  9. Type the following command, and then press ENTER:bcdedit -create {bootmgr} -d "Description"Note Description represents the description for the new entry.
  10. Type the following command, and then press ENTER:bcdedit -set {bootmgr} device partition=Partition:Note Partition represents the letter of the partition. Typically, the letter is C.
  11. Type the following command, and then press ENTER:bcdedit /displayorder {GUID}Note GUID represents the GUID that you obtained in step 8.
  12. Type the following command, and then press ENTER:bcdedit /default {GUID}Note GUID represents the GUID that you obtained in step 8.
  13. Type the following command, and then press ENTER:bcdedit /timeout ValueNote Value represents the time in seconds before the Windows Boot Manager selects the default entry that you created in step 12.
  14. Restart the computer.
May 28, 2012 | HP Pavilion m8417c PC Desktop
How can i reformat my laptop acer aspire 4736z i have my genuine vista os can you teach me step by step...
If you backed up your files, boot off the CD, during startup you should see a message "hit any key to boot from CD", hit any key. Follow the setup prompts. When it gets to the partition pick, delete the partition and format it again during setup.
However please be aware there may also be a recovery partition on your pc if vista was installed by the factory
May 12, 2011 | Computers & Internet
How to reformat laptop
  • 1
    If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
  • 2
    If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
  • 3
    If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
  • May 05, 2011 | Computers & Internet
    I have i dell inspiron 1525 but its operating system (vista basic 32 bit) corrupted. how and where can i get a free download of vista basic 32 bit because i dont have the original disc, so that i can...
    Hi!
    You can try using the recovery partition of the hard drive of the computer, if the recovery partition is still alive, it will let you reinstall Vista back, you can inititiate this by pressing CTRL + F11 key whhen you turn on the computer. There will be no idication of recover on screen instead it looks like windows is startin to startup recovery. In the window you see below the active startup recorey there is, in blue, something like advance recory or something like that. When you press it you will see dell factory recovery. Hope this helps.
    Apr 15, 2011 | Dell Computers & Internet
    Toshiba satellite L300 will not boot up. error code 0xc00000e9
    What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
    Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
    1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
    2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
    3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
    5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
    6. At the System Recovery Options Dialog Box, click on System Restore.
    7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
    8. Click Finish to restore the system.
    Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
    5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
    6. At the System Recovery Options Dialog Box, click on Repair your computer.
    7. (Click the operating system that you want to repair), and then click Next.
    8. In the System Recovery Options dialog box, click Startup Repair.
    Hope this helps
    Ray
    Mar 07, 2011 | Computers & Internet
    I want 2 reset my entire dell d630 laptop How do I do this I don't have any of the passwords
    Hey,
    I hope when you say that you wish to reset the system you mean you need to go to the factory settings. If you wish to go to the factory settings and even if you do not remember the password, there is still a way to do it. But in order to do it you need to have the OS disc from Dell. You have one, you can perform the following steps. It works for Vista:
    HOW TO RESTORE DELL LAPTOP TO FACTORY SETTINGS USING DELL OPERATING SYSTEM WINDOWS VISTA DVD
    1. Insert the Dell Windows Vista DVD into the DVD drive, and then restart the computer. 2. During the startup process, repeatedly press <F12>. 3. In the Boot Device Menu, press the <Down Arrow> to select *Onboard or USB CD-ROM Drive, and then press <Enter>. If the Boot Device Menu does not appear, restart the computer. (You might not get Onboard or USB CD-rom Drive in that case if you get any option that says anything about CD or DVD, select that option) 4. When the Press any key to boot from CD or DVD screen appears, immediately press any key to start the computer from the Windows Vista DVD. For example, immediately press the <Spacebar> when the Press any key to boot from CD or DVD screen appears. If you do not press a key immediately, the computer may not start from the Windows Vista DVD to do image restore. Instead, the computer may try to start the currently-installed copy of Windows Vista operating system. If this situation occurs, restart the computer, and then repeat steps 2 and 3.
    5. When Windows Vista starts from the Windows Vista DVD, other screens may appear during the startup process. If other screens appear, accept the default options, and then continue to the language settings screen.
    6. On the language settings screen, click the appropriate language in the Language to install list, click the appropriate time and currency format in the Time and currency format list, click the appropriate keyboard layout to use in the Keyboard or input method list, and then click Next. 7. On the lower-left corner of the Install now screen, click Repair your computer.
    8. If the Windows Vista Setup program detects any problems on the computer, click No when the program displays the following message:
    Windows found problems with your computer's startup options.
    Do you want to apply repairs and restart your computer? 9. In the System Recovery Options window, under Operating System, click Windows Vista (TM) Version, even if this entry is already selected, and then click Next to display the Choose a recovery tool window. 10. Click on Command Prompt 11. Type path d:\windows;d:\windows\system32 and press <ENTER> key 12. Type d: and press <ENTER> key 13. Type cd tools and press <ENTER> key 14. Type PCRestore and press the <ENTER> key and Dell Factory Image Restore window will appear 15. Click on Next and Confirm Data Deletion dialog will appear 16.Place a check mark beside "Yes, reformat hard drive and restore system software to factory condition" for the final confirmation & click on Next when ready The restoration process takes approximately 10 to 15 minutes; the format bar will run back and forth (See Image 17. Click Finish to reboot system
    Jun 25, 2009 | Dell Latitude D600 Notebook
    I want to take my acer 3690 back to when i bought it
    There is no way to roll back from Vista to XP. If you still have an XP CD Key you can re-install using a windows disk of the same type using your code. All the drivers should be downloaded first to a CD from the manufacturers web site. Plus any data you would like to keep.
    May 13, 2009 | Acer Aspire 3690-2196 Notebook
    Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
    when you restart try to press F11 while booting..check
    Jan 05, 2009 | Computers & Internet
    Compressed boot manager
    Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
    If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
    The Windows Boot Configuration Data file is missing required information
    More Info MS KB 919529
    More Info MS KB 927391
    This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
    If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
    This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
    • compact /U C:\bootmgr
    • compact /U C:\ntldr
    Aug 28, 2008 | Computers & Internet
    first you need the winxp or the vista installer then the first key upon open up the power of your keyboard press delete for about 5 to 10 seconds to open up your the bios setting.then, configure your bios setting by setting the cd rom as your 1st boot device insert your winxp or vista cd then save and exit the computer will then automatically restart then follow the instructions on screen
    Jan 05, 2008 | Audio Players & Recorders
    Computers & Internet Logo
    403 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
