Question about Yamaha NX-B02 Bluetooth Wireless Speaker
Audio has a whining noise when connected through Bluetooth
When connected to my Blackberry through Bluetooth, the speaker has a high-pitched whine that accompanies the sound. Does it have this same problem with other bluetooth devices? Is there anyway to fix this?
I also own a Yamaha nx-b02 unit. Mine whines too, but only when connected via Bluetooth to my Vaio f series or my friend's htc.
They work perfectly on my older Toshiba laptop wich is equipped with Bluetooth 1.1. I suspect the problem only occurs with Bluetooth 2.x equipped devices. (might be wrong though)
Can anyone else add their experiences please?
Posted on Jun 19, 2010
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
Just replaced a dead battery with a brand new one. Tried starting it and it makes a high pitch whining sound and wont start. Any suggestions of what the problem is? Does it need to sit to charge the...
The basics, your battery is used to provide power to the starter. Once the engine is running the alternator then provides current to recharge the battery and run all of your electrical components. so I would suspect the starter is not working to start the engine.
Feb 16, 2011 | Chevrolet Classic Cars & Trucks
Engine noise coming through one channel
This sounds like alternator whine. Do you have the power and ground connected to your battery, or through the accessory power? Make sure the power and ground wires are sufficient size, and connected to your battery, and make sure you have the power wire fused no more than a foot or two from the battery. If it is only on the right channely, maybe this wire is getting feedback from another wire. Seperate the wires if this is the case.
Wires create magnetic fields, and if a speaker wire is next to a power wire or something, you will hear a noise, typically high pitched whining.
Jul 13, 2010 | Jl Audio E6450 Car Audio Amplifier
I have a Sony STR-DG520 5.1 receiver. My problem is that I can hear a high pitched background whine from all the speakers, even if the volume is set to zero or muted! If I switch the audio source off, the...
do u have the unit earth grounded? sounds like AC hum, most amps have a ground lug, make sure that is grouned and the power plug to o the amp has a good ground.
Jun 15, 2010 | Sony STR-DG520 Receiver
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
Same problem: a high pitch whine after extended driving
Sounds like a dry/failing bearing or power steering pump noise. You first need to try to track down where the noise is originating, and the most likely place is at the front of the engine.
I would start by listening with the hood up while parked with the engine running and the noise present, and seeing if it is coming from there. If so, the most likely cause is something connected to the belt - e.g. AC compressor clutch, tensioner, power steering pump, or generator. Can also be caused by the belt just slipping (warn out belt, tensioner not working properly).
Mar 31, 2017 | 2001 Chevrolet Venture
Whining noise from pc tower
No transistor will make such noise... The problem is not in your M/B. The problem might be due to the fan that cools your processor. So clean dust around the fan thoroughly.
Sep 28, 2008 | ASUS NCT-D (90MSV430G0UAY) Motherboard
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Optical sound problem
i have the same problem with the RZ-4900AV, it manifests itself when any video application runs through either the optical or coaxial input. in my case it's definitely not the optical cable itself, which works fine on another receiver. optical or coaxial input of audio CD's is fine, but a DVD video on the same DVD player gives the high pitched whine. the same with the PS2 on the optical input, audio CD in the PS2 no problem, PS2 game or DVD video gives the whine... i think, unfortunately, it's a crap receiver... and i solved the problem by buying a RZ-6900AV, which works perfectly in exactly the same environment.
Sep 10, 2007 | Sony Playstation 3 (PS3) Console
Yamaha NX-B02 Bluetooth Wireless Speaker  Logo
346 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
