Question about Buck Ford Econline Van 1998-2006 Stereo Radio Wiring Harness
Which fuse handles instrument panel and tail lights on ''98'' E150
Can I see a fuse panel diagram? I have a 1997 Ford E150 van. The headlights work, but the instrument panel lights for the main panel do not, and the headlight high beam indicator is opposite normal. The indicator light is on with low beam and off with high beam. Fuses all good.
  • njcolombana Jun 02, 2009
    Thank you for the response, please respond again. I didn't understand your response.
  • 27 Answers
You have a ground problem most likely located on left kick panel but there are several grounds
Check all grounds thoroughly
I had a similar problem high beam indicator worked backwards
I found s loose ground tightened and it fixed everything
Posted on Mar 02, 2014
  • 22 Answers
Go to the libary infomation area and ask the clerk
Posted on Jan 04, 2013
  • 1,596 Answers
Useualt Same one as PARK Lights
Posted on Jun 02, 2009
Need help finding why I have no brake lights or signals on ford e150 van 98
There are three fuse that can effect the break light from working on your 2008 , start with checking the F39 fuse as well as the F7 and F11 all located in the interior fuse panel. in the box above the brake pedal
Dec 12, 2016 | Ford Cars & Trucks
2003 Pontiac Vibe no tail lights, brake lights and turn signals work just fine. The dimmer switch does not dim the dash lights but does work the dome just fineand the lights for the Heat/AC are off.
The tail lights work off the headlight switch, and there is a fuse for the tail lights. Make sure the fuse is good, first, a 15 amp (blue) fuse in the instrument panel fuse block. Then, you might have a bad headlight switch.
So you DO have dash lights, they just don't dim from the dimmer switch? In the wiring diagram, there is a green wire from a "tail light relay" (in the "Junction Block-Right Instrument Panel") that carries power to all the exterior lamps, as well as having a splice to the Instrument Panel Cluster (illum. bulbs), and to the lamp dimmer, and to the radio bulb.
To do any further testing, you would need a voltmeter or a test light, so you could chase down this power loss. Good luck.
Oct 17, 2016 | 2003 Pontiac Vibe
1994 silverado illumination on instrument panel doesn't work, parking lights and tail lights do not work but headlights and brakelights work fine. All fuses are good. Is this a bad dimmer switch?
No. Dash lights being out could be a bad headlight switch, since the dash lights are routed through the headlight switch, not the dimmer switch. Park and tail lights also controlled by the headlight switch.
Oct 23, 2012 | Chevrolet Cars & Trucks
On a 1976 Econoline 150 Motorhome Van the brake lights are out
is probably the brake light switch. it should be at the top of the brake pedal under the dash.
Mar 11, 2010 | 2003 Ford E150
93 ford van e150 fuse diagram
After exhaustive search, this is as close to your needs as i could find. It's the fuse diagram for a 1996 Econoline... See pages 105-110
http://www.thedieselstop.com/faq/9497faq/download/1997%20Econoline%20Wagon%20Owners%20Guide.pdf
Aug 08, 2009 | 2003 Ford E150
Does anyone have a Manual for 93 Taurus? diagram of fuse box?
i have a 93 Sable owner manual I can sell you for $7 including postage. It's the same car as Taurus. Let me know.
tail lamps fuse 4 lt blue
Instrument panel lights fuse 8 lt blue
tail lamp fuse 15 red
electronic cluster fuse 16 tan
Jun 21, 2009 | 2004 Ford F150
1997 Ford Expedition - cruise control won't work. Need a diagram for the fuse block!Help!
Vehicles involved in the recall include the following:
1998-2002 Ford Ranger
1992-1997 Lincoln Town Car
1992-1997 Ford Expedition
1992-1997 Mercury Grand Marquis
1993-1998 Lincoln Mark VIII
1993-1995 Taurus SHO
1999-2001 Ford Explorer
1999-2001 Mercury Mountaineer
2001-2002 Ford Explorer Sport
2001-2002 Ford Explorer Sport Trac
1992-1993 E150-350 Vans
1997-2002 E150-350 vans
1993 Ford F-Series pickups
1993 Ford Bronco
1994 Mercury Capri
2003-2004 Ford F0150 Lightning
1995-2002 Ford F53 motor homes.
Apr 12, 2009 | 1997 Ford Expedition
WHEN YOU TAKE OFF THE COVER OF THE FUSE PANEL THERE SHOULD BE A FUSE DIAGRAM ON THE BACK COVER .OR WERE THE FUSES PLUG IN IT SHOULD SAY.....IF NOT TAKE OUT EACH FUSE ONE AT A TIME AND LOOK FOR A LITTLE BREAK IN THE FUSE WIRE.......OR GO TO AUTOZONE AND JUST LOOK AT THE REPAIR BOOK FOR THAT CAR OR JUST ASK THEM AT THE DESK THEY WILL LOOK IT UP ON THE COMPUTER GOOD LUCK
Feb 20, 2009 | Buck Ford Econline Van 1998-2006 Stereo...
Buck Ford Econline Van 1998-2006 Stereo Radio Wiring Harness Logo
480 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
handygirl911
handygirl911
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
