Question about Maytag MZD2766GES Side by Side Refrigerator
Stopped cooling I now have 2 Refriderators a Westinghouse and a Ge.Neither one is cooling or freezing.Any suggestions?
    President:
  • 1,902 Answers
Check for power. Also check to make sure that the relay on the compressor is good. Take it off the compressor and gently shake it. If it sounds like a burnt out light bulb then the relay is bad and needs too be replaced. If it is still good. Then you need to check if the compressor is getting power if it is then compressor is bad and it is not worth it to have a tech and spend the money on a new compressor that will cost you more then a new refridgerator itself
Posted on Jun 02, 2009
GE concept 2 fridge/ freezer combo. Freezer suddenly stopped freezing anything . It's cool, not even as cold as the refrigerator part. Any ideas?!
Hello:
Check if there is any frost buildup on the back wall inside freezer. Maybe your defrost system failed and ice is blocking the air flow(no air flow you just got a cooler )
Jul 07, 2017 | GE Refrigerators
Stopped working. lights & electronic touch controls are working. Any suggestions what to check first? Any motor diagrams avail? thanks
first I would call a repair service and see if they give estimates of repair cost . usually when the compressor gives out they do not cool/ freeze .
Oct 21, 2015 | GE Profile PGSS5PJXSS Stainless Steel...
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
GE refrigerater stops cooling/freezing and restarts?
maybe stuck in defrost cycle. usually controlled by a hv board on rear of refrigerator
Jun 21, 2009 | GE Refrigerators
GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Jul 24, 2008 | Refrigerators
Westinghouse LCD TV Not Working
Hello, I have a Westinghouse LCD; model # LTV-20v2SL and it stopped working. I had turned it on, then it just went off...I tried using different outlets, unplugging for a moment or 2 and then re-plugging in; nothing. It was purchased a couple of years ago; fairly new. Any suggestions? Thank
Jul 20, 2008 | Westinghouse LTV-20V2SL 20.1 in. ED-Ready...
Maytag MZD2766GES Side by Side Refrigerator Logo
94 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
