Question about GE Profile Spectra JBP95 Electric Kitchen Range
Thermostat trouble?? I have a Norge glasstop electric oven that we bought refurbished about 4 years ago. It's worked beautifully until recently. It doesn't get as hot as it's supposed to. I'm guessing it is about 100oF colder than it should be, and I've noticed it's getting worse. What is wrong with it?
    President:
  • 1,902 Answers
You are correct it is a thrmostat issue that needs to be replaced. You can go to your local appliance repair store and get one. Or you can go online to repairclinic.com both will have instructions for removal and replacement of T-Stat
Posted on Jun 02, 2009
Where can I buy a Norge model 6498xvs control board. Thanks!
You can try a local appliance parts supplier, but the odds don't favor being able to find the board or an equivalent part because of the age.
Feb 12, 2016 | Kitchen Ranges
Not starting
It will be best to contact any service technician in this case. Gopakumar Gopalan Google
Mar 18, 2014 | Vizio 32" M320VT Razor LED LCD HDTV,...
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
Oven too hot and uneven heat
We had the same trouble with our electric range a few years ago. We had the thermostat replaced and it has worked great ever since. Douglas
Jul 10, 2010 | Premier Kitchen Ranges
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
Can I use cast iron on a glasstop electric range?
yes it is true, the heat transfer will be to great and will crack or explode the glass. definately not recommended.
Nov 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have a 4 yr old kenmore glasstop electric range. Problem exists with the broiler as it comes on when I set the oven to bake.
this is normal
about 8 years ago manufactures started to include the broil element in the preheat cycle to heat the oven faster
it should cycle down once the set temp is reached
Sep 27, 2009 | Kenmore Kitchen Ranges
Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
Dec 05, 2008 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Kuppersbusch EEB9800.0 oven - thermostat sensor defective
you need part number 165047 cable harness and part number 161629 thermostat pt1000 call currys partmaster and get a quote on the parts
Aug 26, 2008 | Kuppersbusch EEB 6800.0 JX Electric Single...
1992 Frigidaire built-in oven with F4 error
f4 is the code for a shorted oven probe try first replacing it
Feb 12, 2008 | Frigidaire GLEB27S7A Electric Single Oven
GE Profile Spectra JBP95 Electric Kitchen Range Logo
85 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
