Question about Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY
Pump does not turn on except for a humming sound and shuts off jumping the electric breaker
I have a magnum 2000 jacuzzi pump that makikes a humming sound when turned on and then the electric breaker jumps after ten seconds of the motor humming. Is this bad
  • frankfaustin Jun 02, 2009
    is the motor burnt
  • Evans St. Romain, Jr.
    Evans St. Romain, Jr. May 11, 2010
    Have you thoroughly clean the pump to ensure it's not jammed? If the motor cannot spin when power is applied, it will definitely pop the breaker. The motor will make a humming sound with power applied, can you see the water moving at all through the glass?
  • 990 Answers
This could be anything from a stuck impeller to bad windings in motor. If you open the pump at the lock ring and remove the difusser from the impeller you can see if you can spin the impeller, If it won't move is it something holding the impeller up remove it. If notit is probally a bad bearing and you should replace the motor. If the Impeller turns try turning it on and caerfully try to spin before it kicks the breaker. If it is sort of stuck and does not want to turn the motor is bad and needs to be replaced. If it spins and won't start same thing, If it spins and starts it is probally a start capicator. Shut the power off at the breaker remove the back of the motor the capacitor will be a small black or silver cylinder with 2 or 3 wires clipped to it. Remove this and take it to a motor shop and get an exact duplicate. and that should fix it. When putting back together be sure to lube all "O"rings and refill with water. Hope this helps.
Posted on Aug 25, 2009
My jacuzzi clicks like it is going to start but does not.
If you have the proper voltage into and out of the time clock, you may have a bad start/run capacitor. I would need to know if it hums and then trips the breakers and if the shaft is free to the point you can turn the impeller with your finger.
Jul 18, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I HAVE A MAGNUM FORCE PUMP. iT WAS RUNNING THIS
It could be the capacitor again, but most likely if it stopped while running, its not that, unless you had a brief power failure. The motor may have a built in thermal overload which turned the pump off. If it only humms then it could either be locked up by something in the impller, or could be the bearings in the motor have failed. If the motor doesn't smell "burnt" then you might stand a change to disassemble the pump. Disassemble the motor and replace bearings. Replace the mechanical seal while you have it apart. OR you could buy a new motor, as it is 10 years old.
Jul 05, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Motor hums, but does not start..
turn off power open access panel and check pump close water valves to pump and disconnect lines ckeck pump for debris that may be stuck in pump blocking impeller if clear than lube motor bearings and try moving impeller back and forth to free motor once free return and test pump
Apr 18, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
I have a magnum pump. when i turn it on. the pump hums and then clicks off like it has shorted out. but i still here it on. it will not pull water from pool
Pumps will **** all sorts of debris and many times the debris is small enough to get thru the strainer baskets and block the pump inlet. Turn the power off at the breaker, remove the strainer basket, and reach in with your fingers and check for debris in the pump inlet.
Clear all you can get out by hand, then on the outside of the pump motor, take the cap off the shaft, and turn it back and forth with a crescent wrench. Then put the basket and lid back on and turn the pump on.... you may need to clear it this way a few times to get it back up to speed, but that sounds exactly like what I've been dealing with at my wonderful pool that's right next to a 50 evergreen dropping needles 24-7 this time of year.... hope you clear it up ....let me know how it goes.
k
Aug 03, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi magnum 1500
Pool pumps are on a circuit breaker. There should be one nearby. Check the breaker first. If the switch is halfway on, it has been tripped. Turn the breaker all the way off firmly and then back on to reset.
Also there is a thermal breaker in the pump. Turn the breaker off and wait a few minutes. It should reset as well.
Also, if you get alot of debris in the leaf basket of your pump (mine is very tempermental because it's next to a small needled deadora tree...) Pull the leaf basket, with the pump and breaker off, reach into the inlet of the pump...it's below the basket and off to one side. Make sure it's clear of debris.
Then take the cap off the the electric motor end of your pump shaft. If it's jammed, take a crescent wrench and turn it back and forth until it frees up. Then double check the inlet again with your fingers.
If the pump still has electrical and it's not able to turn, you'll need to take the motor off the pump ...there are 6 bolts that you need to remove and then the motor with the impeller will come loose from the pump housing. There a 2 small allen screws to remove to take the impeller housing off. you can then clean all the debris out of the pump if needed.
IF there is not electrical to your pump motor, it may be that the motor has burned out, but check all the above first if there's still a hum in your motor when you turn it on....
Good luck on this and let us know if you need further help!
K
Jul 30, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Jacuzzi Magnum 1000 - overheating & looking for manual
Loosen the motor and impeller from the pump by backing off the large plastic nut and take that whole section to an electric motor repair shop for inspection. If the motor is salvagable, they can quote the repair or replacement.
Jul 05, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi pump not pumping
I would probably say that the pump is clogged up or frozen. The motor humms until the heat sensor clicks it off. Try taking apart the front of pump and see if it turns and you should see the problem. Parts are available at most pool stores. Pumps are usually cheaper online.
Jun 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a Jacuzzi Magnum pool pump powered by an AO Smith Motor, 1hp, model #C48K2N117A9, serial #8599. Here's the problem. The control panel/timer, is on the wall next to the pump and I can hear it humming...
If the points in the timer are corroded the timer will run but will not put power to pump. If you have a volt meter you can ck this on the load side of the clock. If no power you just need to replace the clock. get all the info off the clock as you want the same brand for easy replacement but most brands have a virety of clocks that look the same and you want to be sure to get the right one. Mind wich wires are line and load since position changes from some old clocks to some of the newer ones. Be sure you shut the power off at the breaker before you start to replace anything.
Apr 09, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Motor hums then clicks off
Has the motor seemed a little slower in starting than usual? If so then you probably have a weak or defective motor capacitor. Try switching out with a new one.They are inexpensive.Try to turn the motor shaft at rear (under end cap) while it attempts to start. If the motor kicks on then replace capacitor.
Apr 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY Logo
1,006 people viewed this question
Top Jacuzzi Garden Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
