Question about Classic Accessories Cimarron Pontoon Boat
Assembeling the Cimerron Pontoon Boat
We purchaced The Cimerron Pontoon Boat, item # 62008, and it came with no directions in the box. Can you help us?
    Problem Solver:
  • 17 Answers
I have a similar boat, but it's been a year or so since I used it. Here's what I remember.
Lay it all out first. It's very confusing until you get a visual. The seat rests on two bars. These bars span the two pontoons. I believe they use pins, rather than bolts to secure it. You probably have a basket and maybe a trolling motor mount. Get rid of the mount, unless you plan on using it. If you do, it attaches to the rear basket. The basket mounts to the back of the chair and rear bar with bolts.
Next, the leg holders slide in and there should be pins to hold them in place for the right distance. If there is a stand up plate and a casting bar, you're on your own on how to attach them. Obviously they go in the front, but I have no idea how they are attached.
Mine had an anchor, but this was a huge hassle. Much easier to pull to shore than park in the water.
There is probably a mesh type piece that fits under or around your seat with bungies or hooks. It may have a fish measure on it. If it does, that goes to the front.
The oars are merely pinned in at a comfortable spots. There should be oar "stops," that slide over your oars. Again, you have to adjust the length to how long your arms are. They don't slide too easily. And, they are needed so your oars don't slide off into the water.
The side bars should have a hump to rest the pontoons on. Buy a double pump and save some time, (or an electric pump). The following is the most important fact of all, You have two bladders in each pontoon. Inflate them BOTH. Air up one from the front, then the other from the rear, back and forth until the pontoon is ready to burst. This prevents a disaster. If one deflates or is punctured, the other one has enough air to support you to shore. Strap them on and you're ready to go. And I would suggest a practice run in calm water first. They are a little awkward at first. Good luck
Posted on Jun 09, 2009
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
2005 Water Skeeter Pontoon..What kind of pump for the valves
If you look up Halkey-roberts valves you will see the air filler part.
May 24, 2010 | Water Skeeter Guide Lite Pontoon Boat
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
Fuse box location
probbably near the engine or near the battery
Jun 14, 2009 | RTO Oar Sockets
I need a new inflation valve for my colorado pontoon boat
Check E-bay -
Item number: 310151809453, Pontoon Boat Boats Outdoor Parts Repair Kit Kits black
What is your problems with pontoon bladder
Thanks for reply
May 30, 2009 | Sage Colorado Pontoon Boat
Classic Accessories Cimarron Pontoon Boat Logo
184 people viewed this question
Top Classic Accessories Sport & Outdoor - Others Experts
Are you a Classic Accessories Sport and Outdoor - Other Expert? Answer questions, earn points and help others
