Question about ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard
Computer Not Booting Up
I just bought all the necessary parts to build my own computer including this motherboard,
Seagate 500gb EIDE Hard Drive,
a DVD-R/RW,
Corsair TWINX 2048MB PC6400 DDR2 800MHz (2x1024),
Intel Core 2 Duo E6550 2.33Ghz 4MB 1333FSB CPU,
Acer AL2216WBD 22in Wide 5ms DVI Black LCD Monitor,
XFX GeForce 8800 GTS Extreme Video Card -  640MB DDR3, PCI Express, SLI Ready, (Dual Link) Dual DVI, HDTV, Video Card
and a 550watt power supply
thats the setup i have and when i power up the computer absolutely nothing happens as far as i know everything is plugged in correctly and power is run to each part i have installed aka fans work, hard drive spins, fan on video card works, dvd makes noise due to the fact that its reading my win xp pro disk, and then nothing shows up on my monitor, also after about 5 minutes of having the pc on it shuts off. My guess is that the psu is too small
  • nickoy03 Nov 06, 2008
    Same Board and Same Problem
  • 656 Answers
Normaly ther are two reasons for pc not showing the disply
1 memory card mismach
2 graphics card mismach
get the specification of the mother board and correct the above errors the pc will work if u need more assistace please write to me
Posted on Nov 30, 2007
Seagate 160gb hard drive recognized in device manaager but not my computer why
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps you
Aug 24, 2011 | Barracuda Networks Seagate ST3160215A...
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
When i log in BIOS menu of hard disk space I get unknow device and then as you go into windows not leave me and my written mistakes.
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 04, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
My seagate barracuda 7200 80 gb having s/n: 9qz0c2zz is not recognize by my computer im using windows xp operating system
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to install secind sata hard drive
It all depends on how many SATA ports are available on your motherboard.
Older motherboards (EIDE+SATA) usually only had one SATA port. In that case I'd advise purchasing an internal PCI SATA card (around US$ 30).
Modern motherboards (SATA + legacy EIDE) have two, four or even six SATA ports available, and you basically just have to screw the hard disk in an empty slot of the appropriate size (3.5"), and connect the cables. You may have to purchase both data and power SATA cables though. Then, format and install the drive (advice: use the one OS you use more often) from Control Panel > Administrative Tools > My Computer > Disk Management. And you're done.
Feb 22, 2010 | Computers & Internet
Not Sure What Power Supply to use in my computer
750 Is PLENTY for your gear. Go hear and see. 750 can run 2 videos, 4 hard drives +
http://www.thermaltake.outervision.com/
Jun 20, 2009 | Thermaltake Toughpower 750-Watt Power...
I bought this Seagate Freeagent external hard drive less than a year ago and the other day when I plugged it in I came to the cold realization that it had overheated. There is a known problem with the...
Most of these external hard drives are just regular old 3.5" or 2.5" hard drives in some sexy looking enclosure. Hopefully just the power supply to the drive overheated and did not do any damage to your data.
Disconnect the unit from the mains (duh!) and carefully disassemble the unit until you can get at the drive itself. Disconnect the drive, and see if it is an EIDE or SATA drive. Again, the drive itself is going to look a lot like one your've seen inside your computer because in 99% of cases it is the same thing.
Purchase another external enclosure for the proper type of interface (SATA or EIDE), or , if there is room in the PC itself, actually install the drive in your PC as an auxiliary drive.
Data retrieved.
Voila!
Mar 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Connecting my Seagate 500GB USB drive reboots PC continuously.
update the firmware from seagate official,sir,any problem u can contact with me,thanks honglake@gmail.com
Nov 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Are you running one or two video cards?
If just one, 550w should be plenty of power. Double check ALL connections and make sure that the ram and all add-in cards are FULLY seated.
Also check to see if the video card requires its own power plug. If it does, it will have a connector on it for you to attach a lead from the power supply.
Also make sure that you have both power connectors plugged into the mainboard, theres one thats only 4 pins and then of course the larger one of 24 pins.
If all connection look good, then start with the basics. Break it down to just the power supply, mainboard, cpu, one stick of ram and the video card... unplug everything else from the mainboard including drive cables and any add-in cards. And check to make sure you processor is seated properly as well as the ram and video.
Let me know what you find.
Oct 23, 2007 | ASUS P5N32-E SLI PLUS (0610839148967)...
ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard Logo
184 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
