Question about Car Audio & Video
My kenwood kvt 514 is in protect mode
My kenwood was working fine until i started to put my rca cable in then it went into protect mode and i cant get it out.. this is the thrid unit i had which this happen to me...the rca cable work just fine with my other radio
  • maurice_brow Jun 03, 2009
    thanks ill take that into consideration
  • 87 Answers
It sounds like your amp is not grounded properly and is tryin to use your radio as a ground through the RCA's or there is a bad channel (dead short) in the amp.
Posted on Jun 02, 2009
    Problem Solver:
  • 8 Answers
Ive had the problem before its a bad ground or a power cord touched something it shouldnt the protect mode is so u wont blow the system if it dosnt go off protect there is a constant problem just unhook all power wires n wait for 15 seconds hook back up and it should comeoff protect mode and if it dosnt then rewire everything you should find 2 wires toutching Josh E. pal. TX car audio pro
Posted on Nov 17, 2009
I had the problem with my kenwood radio. I just reset the radio, and it was good to go
Posted on Oct 20, 2012
How can I update tha software for keenwood KVT-514
Try this link. http://www.helpowl.com/p/Kenwood/KVT-514/Research/53126?search=Kenwood+Kvt-514+Update&x=79&y=17
Feb 17, 2013 | Car Audio & Video
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Apr 02, 2011 | Kenwood KVT-514 Car DVD Player
I have a Kenwood KVT-514 CD/DVD player that I just installed, But in getting no sound, The Radio works fine but when i try to you a cd or a dvd there is no audio. I've checked my connections seval times...
it sounds like you are using an amplifier. if so you are probably using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on. the power antenna remote wire turns off when leaving tuner mode.
Feb 17, 2011 | Kenwood KVT-512 Car DVD Player
Kenwood KVT 514 in dash radio. Ipod classic is connected through the usb cable. Ipod is playing and showing onscreen progress, however, there is no audio coming out of speakers. Have been unable to make...
you need to purchase the ipod cable... your ipod is connected through the usb cable which does not provide sound to the unit but everything else works
Aug 15, 2010 | Kenwood KVT-514 Car DVD Player
Kenwood kvt 514 can't turn on the sub
in the main option menu for choosing tuner dvd video etc. scroll down one and youll see "standby" put that on then scroll through the options and turn on the sub
Jun 28, 2010 | Kenwood KVT-514 Car DVD Player
What mp3 player will work in the usb port on the kenwood kvt-514?
You can put a USB thumb drive in this port, and it will play mp3 files from that drive.
You can also buy an iPod interface that will let you plug in an iPod or iPhone to the USB port.
Jan 27, 2010 | Kenwood KVT-514 Car DVD Player
Protect mode??
Check your speaker wire and terminals at the speaker, it's shorting. The receiver goes into protection to keep from causing damage to itself.
Jul 04, 2009 | Kenwood KVT-512 Car DVD Player
Car Audio & Video Logo
1,835 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
