SOURCE: DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
SOURCE: wat the hell is wrong
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
SOURCE: Dayton 600,000 btu heater oil fired
i have a 600,000 btu oil fired heater, will not come on, but i can make it come on manually,
SOURCE: I have a Dayton 110,000 BTU need back plate
Look up Grainger or WW Grainger on the web they should be able to help you find the part.
SOURCE: I need a service manual for a Dayton oil fired
I have a manual for a Dayton 3E218E. If you want a copy email me at [email protected] and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well:
http://www.bealsmotor.com/
Dayton Portable
Oil-Fired Heaters
PARTS:
Ph. 1-800-323-0620
24 hrs / 365 days a year
105553
2E510F, 2E511F, 3E218E, 3E219E
Please provide following information:
-Model number
-Serial number (if any)
-Part description and number as shown in parts list
102548-03 (part you need)
Thanks for choosing FixYa,
Kelly
