Question about Quickie Wheelchairs Health & Beauty
Have aspire power wheel chair. Batterys have 12 volts across post. Chargers light is on, have 13.5 volts across battery with charger pluged in. Chair will not run at all. No power light on controller or does not show to any charge. Thanks
  • dieselpow34 Jun 02, 2009
    I have cleaned and tightened all battery post and reseated all connections. The charger light is on where you plug 120v ac cord into. But there is no power light or does not show any battery charge on controller. Do you have wiring diagram?
  • dieselpow34 Jun 17, 2009
    This site is total waste of my time. I can google same they can. Maybe I did not read fine print. This cost me $18.00
  • 13,433 Answers
Email billing support at - premium.support@fixya.com
Posted on Jun 17, 2009
  • 377 Answers
  • Check the wires connecting the battery and check if the battery is still ok and also check the battery terminal if it is fix.
  • 10,515 Answers
Regarding the wiring diagram, the link would be :-
https://www.quickie-wheelchairs.com/images/part-graphics-500/pf-modular%20tilt%20assembly-freestyle.png
Infact, i have found a list of wiring diagram,You can check the below link :-
http://images.google.co.in/images?q=aspire+wheelchair+wiring+diagram&hl=en&client=firefox-a&channel=s&rls=org.mozilla:en-US:official&hs=VNP&um=1&ie=UTF-8&ei=F94kSrm8KMSMkAWIt8yuBw&sa=X&oi=image_result_group&resnum=1&ct=title
Copy and paste the link in the browser and press enter.
More likely, it seems a fault in battery.Check the battery voltage as well.
Any further help, let me know.
Thanks for using "Fixya".
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Jun 02, 2009
  • taran_2005
    taran_2005 Jun 17, 2009
    To be honest, if you ask for an apple, we would offer an apple. The comment you posted on jun 02, 09...You have asked for Wiring diagram. I offered you the solution that have all the wiring diagrams.
    And regarding your initial problem, it's already solved by an expert.
    First have the batteries tested to be sure that they are good. Just
    because they are "new" doesn't mean they are good. Then with the
    batteries disconnected plug the charger in and turn the chair on. This
    will tell you if the charger is good.
    If both of these are good then you have an electrical problem. You need to call a local tech.
    Thanks.
    President:
  • 2,559 Answers
Check the connections at each connector,this seems to be a common problem on this model.
What makes the on board charger not work an how cah it be tested to see if it is good.
There is a fuse in the charger and another in the chair for the charging circuit. Poor connections to the controller and at the batteries will do it too. If the batteries have been completely discharged, then the onboard charger does not have enough power to start recharging them. If that is the case, use an automotive 12 volt charger that has no automatic charging circuits in it to charge them individually. That means removing both batteries from the chair and connect the charger to one battery at a time. You can test the charger with the batteries disconnected and measuring the voltage on the wires you just took off the batteries. The voltage should be 28 volts or so if the charger is working.
Jun 29, 2015 | Jet 3 Ultra Power Chair
Invacare battery charger 24 volts no output if not connected to battery?
If the battery has stood for two years with out a charge it will no longer be able to hold a charge renew it . most modern chargers need to detect battery voltage before they will charge .
Sep 17, 2014 | Health & Beauty
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
May 22, 2011 | Jet 3 Ultra Power Chair
Battery will not charge. No power indications when charger is pluged in.
If your charger light does not come on when you plug it into the wall, the charger may need to be replaced.
If the controller does not react at all after the charger has been connected for serveral hours, there may be a bad fuse. Even if the batteries are low, the controller should at least flicker on and off to indicate that is is trying to come on.
If the charger lights up when you plug it into the power chair, but the power chair does not respond when you turn it on while the charger is connected, or the chair will not power on after the charger has been connected for at least 8 hours, the batteries may need to be replaced. Power chair batteries will oxidize and go solid if they are not maintained properly or have been stored. Please consult your owner's manual for the type of batteries needed; most likely it is a U1 12 volt 33amp battery, which can be purchased at Batteries Plus or Interstate Battery for around $75-$150 each.
Dec 14, 2010 | Jet 3 Ultra Power Chair
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
Plug charger in and will not charge the fan on the charger quits running in a few seconds it will beep with charger pluged in and when you unhook charger it clicks like a dead battery i wonder if charger...
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Oct 02, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Hello, i have a invacare wheelchair that has 2 12v sealed batteries, wired in series at 24v. I wanted to find out the charge plug has 3 prongs, which should be -. ground, . over vice versa, how come there...
Salty The charger detects the batteries when it is plugged into the charger port. With the older chargers you could measure the output of the charger by measuring across the two outter pins. With the newer chargers there is no output until the charger is plugged into the charger port. Now on the M51 you should have an on-board charger and the cord plugs into the back of the chair into a three pronged plug. Now if you plug the on-board charger into the wall socket and look at the rear of the chair low to the ground you should be able to see a red and yellow light (red and green when fully charged). With this charger plugged in you can take a digital voltmeter set it on 200 v dc and plug the leads into the two outter holes in the charger port under the front of the joystick you should read 27-30 volts when charging and 24-27 volts fully charged and the charger unplugged. Hope this helps you
Sep 20, 2010 | Invacare Pronto M51 Power Wheelchair
My chair is not charging. We are getting 34 volts
Hi. A voltage of 34 volts is way to high. Most chargers are limited to about 28.5 volts. You will quickly dry out your batteries at 34 volts. I would say your charger is very faulty.
You have probably already destroyed your batteries at that charge rate.
Are the batteries new or a couple of years old.
I serviced a machine last year, that, according to the owner, had been through 6 sets of batteries in 4 years. His charger had the same problem as yours.
Good luck. Neil.
Jun 20, 2010 | Jet 3 Ultra Power Chair
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Apr 02, 2010 | Pride Jazzy 1113 Power Chair
Health & Beauty Logo
118 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
