Question about Goldstar LG LUCKY WG1800R Room Air Conditioner
Evaporator make ice up
Choking evaporator
  • 142 Answers
Clean the filter and the coils. Home depot has coil cleaner in a spray can that will work well for this. Make sure you have good air flow across the evap. If this doen't work, it could be low on refrigerant charge.
Posted on Jun 02, 2009
Deli case icing up at evaporator inlet
Most deli units are gravity cooling units and it is normal for the evaporator to be iced up if your unit has fans it still is not unusual, the ice will melt when the unit cycles off. If the evaporator is only iced up on one end, you are low on freon.
Feb 26, 2013 | True Deli-Cases TSID-48-2-L Refrigerator
Refrigerator is not cold but motor is running.
Hello and Welcome to Fixya,
This is one of the most common problems in most of the refrigeration appliances. What's going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Unplug the refrigerator and pull everything outta the freezer, and I mean everything.
  • Remove the bottom panel inside the freezer so you can see the condensate trough in the back of the freezer.
  • Notice that the condensate trough is filled with ice- all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed- don't start hacking at it with an ice pick because there are chances that you'll just end up puncturing the evaporator and you'll turn a simple, inexpensive repair into a majorly expensive one.
  • Use hot water to drain all the frosted ice that is visible.
  • Re-place all the units removed during the process.
  • Once all the ice is cleared away and the condensate drain opening is cleared, you are done.
Best of Luck,
Please do rate my solution, If found helpful.
Regards.
Dec 21, 2010 | Viking DDBB363 Bottom Freezer Refrigerator
THE FREEZER IS BLOWING WARM AIR
Best of Luck,
Regards.
Nov 20, 2010 | Roper RT18HDXKQ Top Freezer Refrigerator
Fridge/freezer works fine but a squiling sound is coming from the fan in the freezer, but only when its not running
Hello and Welcome to FixYa!
This usually happens, if there is excess choking from ice in the evaporator coils...The excess frosted ice in the chamber extends to the evaporator fan, thus trying to choke/stop the fan... Whenever the fan gets start pulse from the controls, it hurdles the movement and the noise comes. Remove the blockage to the fan (if any), else you need to change the fan motor bearings...
Best of Luck,
Please Do rate the solution, if Found Helpful,
Concerned.
Sep 18, 2010 | Kenmore 64802 Top Freezer Refrigerator
The fan is producing continuous sound. looks like the fan is not rotating. It stops for a while and then, in couple of minutes, it starts again.
Best of Luck,
Concerned.
Sep 18, 2010 | True GDM-49-RC Refrigerator
What can i do if my fridge is not cooling?
Refrigerator mal function can be due to several reasons...To trouble shoot poor/no cooling problem, you need to carefully check all the below quoted possibilities one by one:
  • Start Relay (Compressor Clicking won't Start in case of faulty).
  • Bad/dirty Condenser.
  • Defrost timer Settings.
  • Cold Control Settings.
  • Defrost (Ice built up on the evaporator coils that chokes the air flow to the freezer/refrigeraot compartment).
  • Evaporator Fan.
  • Main Control Board mal function.
You need to cross check all above quoted possibilities one by one to locate/trouble shoot the problem.
Best of Luck,
Your token of appreciation in form rating will be highly obliged.
Concerned.
Sep 18, 2010 | Avanti Refrigerators
The freezer frosts and ices up so bad it plugs the holes that cool the refrigerator. Then this morning there was a puddle of water in front of it
This is one of the most common problems in most of the refrigeration appliances. What’s going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Notice that the condensate trough is filled with ice– all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed– don’t start hacking at it with an ice pick because there are chances that you’ll just end up puncturing the evaporator and you’ll turn a simple, inexpensive repair into a majorly expensive one.
Best of Luck,
Regards.
Jan 25, 2010 | Haier HTQ21JAAWW Top Freezer Refrigerator
Refridgration is not cooling
hi
same thing happened to me with a westinghouse upside down fridge freezer yesterday. i talked to a mate of mine who is a refrigeration mechanic and he said to check the air flow going into the fridge via the freezer and to see if the fan above the evaporator was working. he also said you would probably have to have the fridge light switch depressed as the fan is designed to only run when the fridge door is closed. when i removed the cover in the back of the freezer to inspect the fan i found the fan was spinning okay, but my evaporator was choked up with ice. i gave it a good defrost and clean out and everything seems okay now. i think the heating element around the evaporator (frost free) is not working and that is why it has iced up. apparently it is very important to have good airflow in and around the evaporator so if it is iced up or you have too much stuff in your freezer it will not be efficient and your refrigerator performance will suffer.
to have a rough idea on whether you have enough gas in your system, he suggested feeling the pipes coming out of the compressor. in normal conditions one should be quite hot to touch and the other should be a little bit cooler than room temperature. your condensor (which is the big coil up the back of the fridge should be warm and your evaporator (coil behind a cover in your freezer should be cold to touch)
hope this helped
john
Jul 16, 2008 | Refrigerators
Whirlpool Designer Style Refridgerator Model # E8220KXFW01
Check the condensor coils in the base - probably choked full of dust and lint. RTFM!
Jan 08, 2008 | Refrigerators
Heating & Cooling Logo
138 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
