Question about Samsung HCN4727W 47" Rear Projection Television
HCN4727 hour glass picture and colors off
I have a hour glass picture and the colors are off i could manually line up the blue but the red does not move at all. Could any one help me please.
  • 2,920 Answers
Re: HCN4727 hour glass picture and colors off
All of you are having the same problem with your convergence boards they need to ne replaced. about 250.00 in a shop
Posted on Sep 03, 2008
0 characters
3 Points
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Projection Televisions
I have a HDTV 524159 RCA, it has an hour-glass effect on both directions. On the left side, it hour-glass inward with red and yellow stripes and on right side blue and light blue stripes. It hour-glass...
Hi Sandy, the problem with your TV is called "convergence". It can be a problem with the convergence board or more likely in this model in the power supply or deflection circuits. Unfortunately, troubleshooting by a technician is required.
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
Picture goes into an hour glass shape. red/orange color on one edge of the hour glass and green/blue color on the other edge.
You have a bad cap or two in the horizontal deflection [Pincushion problem] and you may have to look for a burned resistor. Use your vision to inspect burned areas on the board, this will most likely tell you where the problem may be. Area should be between the Vertical and Horizontal deflection. Look for the flyback transformer that is the board you are looking for! Hope this will you a good start. Thanks for asking!!
Oct 11, 2009 | Zenith IQB60M92W 60" Rear Projection...
3-D picture with color lines
Seems TV has dry/ cold solder joints (loos connections) in convergence out section.
Please check cold/ dry solder joints in convergence out section in TV, specially on pins of convergence out ICs. resolder these solder joints and all would be fine.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
Hourglass shaped red
I need to see a picture of the TV set. send a photo to
Jun 05, 2007 | Akai PT4298HD Rear Projection Television
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Samsung HCN4727W 47" Rear Projection Television Logo
155 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
