Question about Microsoft Xbox 360 Console
Error e74 on xbox 360
How to fix it my 360 says e74 (1 light) when i plug in the AV or HDMI cable, but if no AV is plugged in, there is no error light. Ive restarted it, but to no avail. AAAH!
    Novelist:
  • 174 Answers
Hi There,
You have a graphics encoder chip at the rear of the console labeled 'ANA'. This chip will require resoldering / reflowing.
We offer competitivley priced repairs and a 4 month warranty also.
FixMyConsole
Posted on Jun 03, 2009
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Tip
How to Repair the Xbox 360 E74 Error
Oh no, it happened, you are the victim of an error on the <b>Xbox 360 E74</b> feared. Well do not worry my friend, in this article I will show you exactly how to <b>fix E74</b> error free shipping on your system in two months.<br /> <br /> The first way to correct this error is very simple, it might just be the AV cable. The first thing you can try is to unplug the AV cable and blow off the dust that could be built up contacts. Then try hooking it back up and turn it on.<br /> <br /> If you still have errors trying to get a new AV cable, or you can borrow one from a friend so you do not buy a new cable, if not the solution either. Once you have the new AV cable, plug it in, turn on your <b>Xbox 360</b>, and if the error is still ongoing, so you must go to the following method to determine the<b> error E74</b>.<br /> <br /> If the AV cable is not working, you have to go to a bit of a more complex method to correct the error. You can still fix, but the methods can be explained in an article.<br /> <br /> You can find the <b>Xbox 360 repair</b> guide on the internet which are very detailed instructions on how to correct the error E74 and other errors, such as freezing, no video problem and the Red Ring of Death. These instructions are usually very detailed step-by-step. Better manuals including pictures and video of the process, so you can be sure you understand every step of the repair.<br />
on Mar 08, 2011 | Video Game Consoles & Games
Xbox360 e74
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/kb/e74-error-appears-when-you-use-your-xbox-360-console.aspx?kbid=941377
Oct 17, 2010 | Microsoft Xbox 360 Console
One red light flashing on xbox360,code e74 showing on screen
If you have 1 red light flashing it is normally E74 or some other E error you need to stop the heat.
You can send it in and Microsoft will do it for you or you can repair it yourself using a good guide
Dec 23, 2009 | Microsoft Xbox 360 Console
Xbox360 e74 error code
This problem occurs when the Xbox 360 console experiences a general hardware failure. Contact Xbox live 1-800-4my-xbox
Sep 19, 2009 | Microsoft Xbox 360 Console
E74 xbox 360 AV cable?
to fix the E 74 problem, i sudgest going to http://llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm. they have a step by step solution for both the red rings of death(3, and 1) or the E 74 error. i sudgest buying the kit they sudgest, its $29.99 or so. then just follow the step by step instructions when your kit gets to your house
Feb 24, 2009 | Microsoft Xbox 360 Console
One red light bottom right hand corner
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74 system error
E74 is NOT caused by a bad AV cable, it is NOT caused by the ANA/HANA scaler chip. It is the solder points on the GPU that have cracked. You must use a heat gun and do the XCLAMP to fix it. Shops normally charge $75-100 to fix that.
May 20, 2008 | Microsoft Xbox 360 Console
E74 error
E74 for XBOX 360 is a hardware failure.  Unplug all controllers, hard drives, memory card(s).  Unplug and reseat the power cable and the A/V  cable.  Check the power supply to see that color led lights up when you turn the console on.  If it is red or orange it is an issue with the power supply (either overheating or too much/too little power.  If you are plugging the power supply into a cheap surge protector plug it directly into the wall.  If none of these suggestions work then you need to contact Microsoft.
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
239 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
