Either in v/m or on answer machine
SOURCE: message waiting indicator
Try holding the mute/find handset button on the base unit for about 5 seconds and the light should stop flashing.
SOURCE: uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
SOURCE: red blinking light on answering machine says CL then A ,suppost to tell me if there is messages
This indicates that you need to set the clock.
press "menu" button until you here "change clock"
Press "select" button until you here your desired setting
Press "time/set" button to confirm selection
