Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore 665 no lights on panel water in bottom
Water in bottom of dishwasher, no lights are lit up on control panel. I checked and reset fuse. Not the problem Kenmore 665 model
  • Anonymous Mar 24, 2014
    There is water remaining in the bottom of the washer and the control panel will not light
  • 530 Answers
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Posted on Jun 02, 2009
  • erica graber Jun 02, 2009
  • Richard Moehling Sep 08, 2012
    Checked fuse - I have continuity across fuse
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Kenmore dishwasher 665-1703 wont stop washing
Unfortunatly you are looking at the timer which is now built into the controller which would need to be replaced. If the relays are fused shut on the timer or the gears are missing some teeth then you will only get sofar I the cycle and the washer will just stay where it's. Sorry
Sep 08, 2012 | Dishwashers
Breaker at dishwasher trips right after water has filled.Spray arm has not turned.
There is an electrical short circuit, check/reverse the leads going to the pump or heater.. Sounds like controls and water valve are fine. If wires are not connected to the correct locations you need a new motor because it is internal.
Aug 26, 2012 | Kenmore 665
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
No power suddenly on the control panel... kenmore elite model 665-1374/665-1384 Worked one day and not the next. Breaker is on, no blockage at water line... connections all tight. It's only 14 months old!
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Dec 30, 2009 | Kenmore Dishwashers
Dishwasher won't run. Light flashing on Air-Dry button.
check bottom of dishwasher, front left, round breather, gets clogged...clean and restart
Mar 13, 2009 | Dishwashers
Kenmore dishwasher 665. No lights, tub not fullly drained.
check with a ohm meter should read 0 ohms or around 0
Dec 14, 2008 | Kenmore Dishwashers
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
May 07, 2008 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
1,598 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
