Question about Samsung VP-D361 Mini DV Digital Camcorder
I have the samsung vp-d381i camcorder and a desktop computer...
I do not own a laptop but i want to transfer video footage from my cam corder to my computer i have bought a firewire cable but it is for a laptop so i cant use it. is there any cables that work with dv to usb or is the laptop option the only way i have to do it?
    President:
  • 272 Answers
Unfortunately dv or also called mini firewire is a firewire cable. There is no mini to USB cable out there. On the other hand it is very inexpensive to add a firewire card to your computer if you have any available expansion ports. here's an example on Amazon but you can find them much cheaper if you look around;
http://www.amazon.com/Belkin-F5U501-APL-Internal-FireWire-Card/dp/B00009WPOM
Posted on Jun 02, 2009
Can i buy a lead to go from my cam to a laptop to i can put the tape footage on a disc?
yes, ask at any reputable retailers and they will point you in the right direction. You probably need a firewire cable.
Apr 28, 2012 | Samsung VP-D361 Mini DV Digital Camcorder
I have a samsung VP-D70 camcorder and I want to transfer data to my laptop. The DV out on the camcorder is descibed as 4 pin the other end of the cable supplied is not usb (it has 723 on the connector).I...
This is a Firewire cable, also known as DV or IEEE 1394. Sony call it i.Link. It is not compatible with USB and you cannot get a lead to connect it to a USB port. There are converter/adapters that are supposed to allow Firewire to connect to USB but many forum posts say they do NOT work for video transfer. Unfortunately, most Mini-DV cameras will not transfer video by USB cable, even when they have a USB connection (it is usually only used for still pictures).
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you had a desktop PC, you could fit an add-on Firewire interface card to the expansion bus. This will come with a driver for the card.
I have a Samsung Mini-DV, and do transfers with it to the one computer I have that has a Firewire port. It is the only thing I use that computer for, and the reason I haven't thrown it out.
Jan 16, 2011 | Samsung VP-D70 Mini DV Digital Camcorder
I have a Samsung DV-D381 MINI Camcorder. What
OK there are NO cables as such for that PC, as of normal, to get Video into this machine you will have to use either, a USB TV/Video card, and use the AV inputs. OR put a Video TV/Video Capture card into a PCI slot, and again use the AV inputs to connect via. The you will have to use the AV leads Yellow, Red & White, OR the SVHS port if available. You will also need software to record the video stream, If you camera has FireWire then you could install a FireWire Card into a PCI slot and hook you via that, you will still have to use software though. Sometimes the camera, has proprietary software to edit and work with the Video from the camera, usually via FireWire. To get said software go to the manufacturers web site, and download a copy.
Mar 15, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
How do i transfer from my vp-d381i to my pc in order to burn them onto a disc?
Connecting to a PC
If you want to transmit data to a PC, you must install an IEEE 1394 add-on card into the PC. (not supplied)
The frame rate for moving images is dependent on the capacity of the PC.
This is straight from manual
You can get the card here.
http://www.compuvest.com/Desc.jsp?iid=989344
Here is a manual if you need
http://downloadcenter.samsung.com/content/UM/200803/20080315141205734_AD68-02562G_VP-D381_ENG_UK_IB_0313.pdf
Good luck
Sep 27, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
Camera won't record a D comes on screen and eject tape comes up.
I have a cam corder model VP-D361 PAL, since i brought i could not use it even a single time, for the past 2 yrs it was kept as it was brought in packed condition, i was using other cam corder of jvc, when i opened and start using it, i found a triangle and a D on the screen, several attepts made by taking out battery, and casset. but still same thing appears,(AFTER REFERING TO USERS MANUAL) it may be a simple problem, or a defective one, since brought a single minute is also not used, kindly help me to solve this problem from a local serviceing centre.at mumbai, india.
My address as below,
K.J.SEBASTIAN
BLDG NO. 7, FLAT NO. 29
BORLA CO OP HSG SOC
DR.C.G.ROAD
CHEMBUR, MUMBAI- 400074
TEL NO. 91-22-2520 5842
MNO: 9892004970,9987904458
Jan 18, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
I want to copy video footage from the tape to the sd card.
Hi!
You cannot transfer the video from Mini-DV to SD card within your camera as your camcorder does not have this feature. If your purpose for finding this function is to transfer your footage to your computer, you may try using the firewire port in your camera to connect it to your pc.
If you need help with the firewire connection, feel free to post a follow up.
Hope this helps!
Nov 11, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
I have a samsung mini dv digital-cam VP-D351 PAL and im trying to connected it to the computer but its not being recognised by the laptop. Thank you for any information that you can give me.....
If you are running windows vista this will be the problem.There are no drivers for vista firewire..If other windows then try samsung support for required driver.
Sep 07, 2008 | Samsung Compact MiniDV Digital Camcorder
TRANSFER VIDEO TO PC
the samsung website has a vista update driver for this problem
Jan 25, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
I am trying to find a way to transfer my video from samsung digital cam. sc-dc164 to my computer so i can edit and make dvds. .
Make sure you have a firewire port on your computer. If not, go out and buy a firewire card. Then purchase a firewire cord. plug your camera into the firewire port using the firewire cord, boot up your video editing software (I use Adobe Premiere, personally. Final Cut Pro is the best to use if you're running a Mac), and capture your footage. Edit your footage if you'd like and all that stuff, and then export the video to your desktop. You'll then have the same quality of what you shot in one file.
Oct 09, 2007 | Sony Handycam CCD-TRV128 Camcorder
Samsung VP-D361 Mini DV Digital Camcorder Logo
1,147 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
