Question about Goldstar LG LUCKY WG1800R Room Air Conditioner
Evervarator make ice up
Choking evervator
    President:
  • 3,433 Answers
Temp setting too low for high humidity. Turn up temp. this allows the unit to stop cooling intermitently so the ice doesn't build up unless it is runs constantly. Good luck
Posted on Jun 02, 2009
My jonstred chain saw has no choke lever
Ian Duncan...
I have no idea if you are bragging or complaining...
I WILL TELL YOU ... I have started many many a chain saw... and the chokes are nearly useless...
FIRST RULE: always use only fresh fuel...!!
Proper sequence for an ice cold saw (optimal adjustment)...
- squish the fuel bulb a couple of times
- set the choke
- couple of yanks until it coughs...
- completely release the choke and the next yank will get you running
If you have NO CHOKE... JUST leave the THROTTLE ALONE
until it coughs... Then start juicing the throttle...
What's a jonstred? Oh... Jonsered
62results for choke jonsered
Jonsered Chainsaw Parts Chainsaw Parts Discount Online Parts
Nov 12, 2016 | Garden
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Jiffy ice auger starts with fuel primer and soon quits starving for fuel ???
To insure fuel starvation try running engine with partial choke.
If it will run with a little choke then it is a fuel problem
Jan 09, 2011 | Sport & Outdoor - Others
Fridge/freezer works fine but a squiling sound is coming from the fan in the freezer, but only when its not running
Hello and Welcome to FixYa!
This usually happens, if there is excess choking from ice in the evaporator coils...The excess frosted ice in the chamber extends to the evaporator fan, thus trying to choke/stop the fan... Whenever the fan gets start pulse from the controls, it hurdles the movement and the noise comes. Remove the blockage to the fan (if any), else you need to change the fan motor bearings...
Best of Luck,
Please Do rate the solution, if Found Helpful,
Concerned.
Sep 18, 2010 | Kenmore 64802 Top Freezer Refrigerator
The fan is producing continuous sound. looks like the fan is not rotating. It stops for a while and then, in couple of minutes, it starts again.
Best of Luck,
Concerned.
Sep 18, 2010 | True GDM-49-RC Refrigerator
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Why will a room air conditioner ice up and can I fix the problem?
Freon leak, How new is it. If you still have a warranty take it back and have them replace it. If it is not under warranty you can try a few tricks. Clean the outside coils with a strong blast of water with the unit off and make sure the filter is cleaned
May 24, 2009 | Goldstar LG LUCKY WG1800R Room Air...
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Heating & Cooling Logo
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
