Question about Garden
My MTD Yard Machine lawn tractor is 15 HP. It will not fire at al. Have checked ground and replaced ingnition switch. Battery replaced is pulling 12 volts. Starter will fire when straight wired. What could be the problem?
  • 136 Answers
It sounds to me like a bad battery or a short in a wire.. if everything else runs fine i think that's the issue
Posted on Jun 02, 2009
Diagram for belts on a 48 cut yard machine
http://www.ereplacementparts.com/mtd-13aq617h118-2003-lawn-tractor-parts-c-20039_20060_133253_24406.html MTD 13AQ617H118 2003 Lawn Tractor Parts
May 13, 2015 | Yard Machines Garden
Lawn mower won't start
Check spark plug grounded when pulling starter to see if you get fire First. Then , spray(if getting spark at plug) starting fluid in a air intake , if motor fires, you're not getting gas so clean gas tank and carb, then , it should run fine.
May 07, 2014 | Mtd 22" Yard Machine Push Mower
My 95 yard machine stays engaged in gear while pushed in or even in park
Outdoor Power Equipment Parts Use the Part Finder Tool from MTD and it will, the variable pulleys and belts need to be uncoupled, maybe try depressing the pedal a little (ON FLAT GROUND) park brake disengaged.
Aug 05, 2013 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Charging system for MTD YARD MACHINE riding mower
under the flywheel is a magnetto system the stator this is what charges the battery
Jan 19, 2012 | Yard Machines MTD Gold 20 HP Lawn Tractor...
My yard machine tractor does nothing when I turn the key. The battery is new. However the tractor is 12 years old. Could this be the alternator?
If it does nothing when you turn the key then replacing an alternator will not help. Numerous things could be causing this condition. I will try to cover a few. Make sure your PTO for the blades is disengaged and the clutch pedal is depressed. Make sure your battery voltage and all connections are good. Also make sure it is hooked up correctly. There is a fuse, usually near the solenoid, you need to check that. If all the above is good check to see if you have voltage going to the solenoid: There is a small wire that hooks to a spade terminal, you need to have 12 volts on this wire when the key is in the start position. If you do not, then you need to troubleshoot your safety switched. If you have 12 volts, then you may have a bad solenoid. Good luck, hope this gets you in the right direction.
Feb 17, 2011 | Yard Machines 155 Torque Briggs Stratton...
My mtd yard machine has develabed a jurking motion going downhill only
need to replace clutch pulley this is easy if you are strong enough put it up on safe blocks rear in the air take a proper wrench put it on the nut take a 1-1/4 pvc pipe slide it over the wrench for leverage this triples leverage put a long screw driver in so the pully wont turn and turn the nut replace with new clutch pulley and belt and watch youre mower pull like new.
Nov 05, 2010 | Yard Machines MTD Gold 20 HP Lawn Tractor...
MTD 46" Yard-Man Lawn Tractor battery connection problem!?
the battery for a garden tractor should have the holes already in it if not you can buy a clamp that you can use that has a hole for what you need. good luck
Apr 11, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
