Question about Qwestar QC280 10-Disc CD Changer
The whole cable system got disconected and I don't know how to get to put it back. I don't have the right tools to do it and prefer to replace it. Where can I buy a new one?
I just want to replace the wired control remote without having to buy a new unit. Is there anyone knows how to get one. Everything is replaceable today, isn't it?
    President:
  • 1,114 Answers
If you go to a car audio shop that sells Sony and has been around a while, chances are they will have one lying around. From what I can tell in the picture (if that's what yours looks like) it's a Sony 55RF or close to. When you go to a shop, take it with you to make sure you've got the right cable. Hope this helps.
Posted on Jun 02, 2009
Sukida sk50 roma
Contact a locksmith. They have replacement locks for these tool boxes. I had mine replaced in 5 minutes.
Jul 19, 2014 | Back Rack backrack 10507tb backrack with...
Both hinges on my PC have popped out and disconnected the screen from the keyboard. I don't know what to do. I've been trying to put them back in myself, but nothing is working. I've resorted...
I hear you... this is like the only thing that breaks on these A45's and its corporate brother - A40's: always starts from the left hinge and if you don't take care of it, the right hinge goes, too. These hinges are the hardest things to find in the world (it's the only part that breaks) I'd try eBay - you can probably get a whole, used machine (either an A40, or A45, and I'd prefer the WiFi ready models) with good hinges for $40 bucks or thereabouts, and put your hard drive, memory into the replacement machine and use it. Hope that makes sense.
Oh, and Toshiba no longer carry these parts so new ones are kinda out of the question.
Aug 31, 2011 | Toshiba Satellite A45-S151 Notebook
Ms excel don't work
you have few steps that you can try
1 if you know the date in whcih it was working fine you can restore the system to back date, here is the procedure
click on start,all programes, accesories,system tools, system restore
2 you can click on start then control panel, then add/remove progames, then right click on the programe you will get the uninstall option and once you click on uninstall it would give you the option to repair, click on repair
3 uninstall the whole office application, restart the computer and reinstall the programe
Aug 14, 2011 | Microsoft Office Professional 2007 Full...
Horn goes off even when not depressed, seems to happen when you put the breaks on, but not every time?
hello there
i asume you have a boxter or 911 2000 and up?
It is a common problem.You will need to replace the whole horn button to fix it or you can try this.
The horn button has two hex bolts holding it to the steering wheel.Once you lose these bolts you can remove it away a little bit !!!but very carefully so you don`t disconect the air bag connector!!! I used to put behind a little soft foam so the horn button does not touch the horn connectors in breaking or on street bumps.
let me know
proporsche@yahoo.com
proporsche
Jul 18, 2011 | Porsche 911 Cars & Trucks
I have a 2000 dodge v6 magnum pickup truck and the speedometer does not work and i wanted to know if there is a fuse that i can replace in the fuse box in the truck itself and under the hood that could...
to save you some time and money take it to a shop and have them put it on a scan tool to see what code if any is in the computer and they can also see what is working and not working while driving the car.this way they can tell you what should be checked out or replaced so you don`t throw a bunch of parts and money you didn`t need to, to fix the problem.it could be the speed sensor at the transmission the connection or the speedometer buffer in the system in the dash or the speedometer head or bad connections at the cluster.
May 03, 2011 | 2000 Dodge Ram 1500 Truck
How to remove the steering wheel without deploying the airbag? I want to replace it with another one like it but customized and install the airbag back to it.
Disconect the battery completely both cables. let it sit disconected for a while 20-30 minutes. Or if you feel safe doing this which it is safe. Both cables removed from battery toch them together away from the power source. This will send any and all left over power stil in system straight to ground and you will be clear to remove steering wheel. Do what you have to doo and the very last thing is to hook up the battery negative cable last.
Feb 11, 2011 | 2006 Chevrolet Trailblazer
Brake Release Cable
Yeah, just trace the cable back to the right rear tire, remove yuor tire and you'll see where it hooks up. You'll need to replace the whole cable, not just splice.
Jun 11, 2009 | 2000 Chevrolet 3500
I need help on replacing a radiator on my 2000 chevy cavalier
Disconnect negative battery cable. If you have Delco Loc or Theftlock audio system, turn off feature which reqiers disconnecting the battery. Make sure engine is cool and turn cap slowly to release pressure. Drain cooling system. Disable airbag system by disconnecting the electrical connector from the airbag system's forward discriminating sensor located on the hood latch support bracket. Remove the cooling fan and shroud assembly. Next loosen clamps for upper and lower hoses then Disconect from radiator. Disconect the coolant reservoir inlet and outlet hoses from radiator. You will need a couple drain pans and rags. If your car has an automatic transaxle, Disconect it from the left side tank of the radiator. Use a back-up wrench on each welded nut while loosening the cooler fitting. Be careful not to bend or brake any lines when loosening the fittings. If they are tight spry some WD-40 and wait about 10 mins. Plug the ends of the disconected lines to prevent leakage. Remove right and left head lamp assembiles. Remove hood latch support brakets from radiator crossmember. Remove condenser mounting bolts. Remove the radiator upper mounting bolts located at the upper left and right ends of radiator's side tanks. Now carefully remove radiator. To install just follow directions backwards. I hope this helped.
May 08, 2009 | 2000 Chevrolet Cavalier
Transmission problem shifting into high
My 97 Jimmy was doing the same thing, codes P0740 & P0753 witch are torqe converter lock up & shift solinoid. I unhooked the wires in the drivers side of the trany and cleaned them with contact cleaner bought at the parts store. I reconected the harness and disconected the baterie for a couple of houres and no trouble since.... 4 days so far Knock on wood........ Hope it helps
Jul 23, 2008 | 1997 GMC Jimmy
Do I have to tear out my wall?
If I understand you right the metal connector is on the wall connector and the wire is off of it if this is the case take some pliers and take the connector off the wall then take the connector and put it back on the wire just slip it in and squeeze the bottom of the metal connector so it tight on the wire this should help..
Nov 22, 2007 | Monster Cable (109611)
Qwestar QC280 10-Disc CD Changer Logo
Top Qwestar Car Audio & Video Experts
xxxxxx xxx
Are you a Qwestar Car Audio and Video Expert? Answer questions, earn points and help others
