Question about Kodak EasyShare M1033 Digital Camera
Set date time
I can't get back into the date time menue to set it correctly. I accidently pressed ok it set on 1 1 2008 how ca I correct date tome???
    Scholar:
  • 62 Answers
To set the date and time:
  1. Press the Menu button.
  2. Use the arrows to:
    • select the Setup menu.
    • select the Date & Time feature.
    • set the date and time.
  3. When you are finished, press the OK button.
Want further assistance?. check user manual in the following link.
http://www.kodak.com/global/en/service/publications/index.jhtml?pq-path=1398#easyshareDigitalCameras
Hope it helps,
~regards,
Jegan
Posted on Jun 02, 2009
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
Explain how to set the date in the bottom right corner of my computer screen
  • Double click the time display on the bottom right of the computer screen to open the date and time properties box. Use the tabs to access settings for time, date, time zone and Web-based time updates.
  • 2 Set the clock for the correct time zone. Click the "Time zone" tab. Click the drop-down menu for time zone choices. Click the time zone choice for your area. Click a check in the box for automatic updates on daylight saving time changes. Click the "Apply" button, then the "OK" button.
  • 3 Set the correct date. Click the "Date and time" tab to show clock and calendar settings. Click the drop-down menu displaying the name of a month to change the month. Use the up-and-down arrow keys to change the year being displayed. Click on a date on the calendar image to set the date. The time can be manually set on this page also.
  • 4 Set the current time. Use the up-and-down arrow keys next to the numeric time display on the date and time page to manually set the clock. Click "Apply," then click "OK" to confirm date and time settings.
  • 5 Click the "Internet time" tab to use a Web-based clock for updates to automatically correct the time. Click the "Server" drop-down menu for listed Internet time sources. Click a check mark into the check box for automatic synchronizing. Click the "Update now" button, then click the "OK" button.
Sep 12, 2011 | Dell Dimension 4700 PC Desktop
How can I change the date and time on my Fuji T200 camera, please
Use the MENU/OK button to the right of LCD screen in lower corner.
1. Press MENU/OK.
2. Press RIGHT side of selector to open Set Up MENU.
3. Toggle up/down to find the Date and Time setup.
4. Toggle with the selector to highlight year, month, day, hour etc
5. When each item is highlighted toggle up or down to find correct number.
6. When all are set press MENU/OK again to exit.
These instructions are on the manual which is on the CD that came with the camera.
Jul 01, 2011 | Fuji Cameras
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
Not getting fax report and want to set time and date on l80 faxph
Press functionand then data registration,press set/ok and it will say user settings,press set/ok and it will say date and time,press set/ok and type in the correct date and time press set/ok and stop!To get the report press function and data registration and set/ok,use the arrow down and scroll to report settings,press set/ok and it will say tx report,press set/ok and use the arrowdown untill u get output yes!Press set/ok and stop!Enjoy!
Apr 24, 2010 | Canon FAXPHONE L80 Laser
Unable to set the correct date. Able to get to menu:additional functions,timer settings and the date and time settings, but unable to change the time
Type everything in and then press OK. If its showing up on scan time then go to Add Funct-System-Date and Time. Make sure time zone is set correctly
Nov 30, 2009 | Canon imageRUNNER 1023iF Black and White...
HOW DO YOU SET THE DATE AND TIME?
It should be in 'settings' on your cell phone menu. Search around your phone. It could also be in 'organizer'. On my old one, it was in 'organizer', and once I went there, there was a 'set date and time' button. Here is the answer from the Vtech website: "Make sure the answering system is on. Press [Time/Set]. The system will announce the current clock setting, then announce "to set date and time, Press Time/Set". Press [Time/Set]. Press [Change] until the system announces the correct day, then press [Time/Set]. Press [Change] until the system announces the correct hour, then press [Time/Set]. Press [Change] until lthe system announces the correct minutes, then press [Time/set]. The system announces the current clock setting. Note: You can press and hold [Change] to advance the mninutes in increments of ten. "
Jun 06, 2009 | Vtech Lands Phones
CASIO DR250TM CALCULATOR
In case you haven't found the solution yet. This is it.
Move buttons to "Print" and "F"
Press CA key
Press % (set Key)
Press "time"
Press and hold down the % (set key) until the numbers come back and start flashing.
Put in the correct numbers.
Press % (set key) again and your done.
Hope this helps.
Linda
Dec 04, 2008 | Casio DR250TM Calculator
Setting date and time on HP office jet J4580
Set the date and time
  2. Press the Left (c01185108.jpg ) or Right
    (c01185072.jpg ) Arrow button to select Basic Setting , and then
    press OK .
  3. Press the Left (c01185108.jpg ) or Right
    (c01185072.jpg ) Arrow button to select Date and Time , and then
    press OK .
  4. After Enter
    date
    appears on the control panel display, use the keypad on the control
    panel to type the date in the correct two-digit format, MM-DD-YY (01-01-10).
    After entering the date, press OK .
  5. After Enter
    time
    panel to type the time in the correct two-digit format, HH:MM (10:15), and then
    press the Right (c01185072.jpg ) Arrow button
    to switch between AM and PM . After entering the time, press OK .
Aug 21, 2008 | HP Office Equipment & Supplies
Cannot set the Time/Date
Setting the Date and Time The date/time needs to be set if/when: Camera is turned on for the first time. Camera is turned on after leaving ViviCam X60 without the battery for an extended period of time. When the date and time information is not displayed on the LCD monitor, follow these steps to set the correct date and time. 1. Slide the mode switch to [replay ], and press the MENU button. 2. Select [Setup2] with the LEFT ARROW button. 3. Select [Date/Time] with the UP ARROW / DOWN ARROW buttons, and press the SET button. The Date/Time setting screen will be displayed:[Setup] [Format], [On/Off]. 4. Select [Setup] with UP ARROW / DOWN ARROW buttons,and press the SET button. Select the item’s field with theLEFT ARROW / RIGHT ARROW buttons and adjust the value for the date and time with the UP ARROW / DOWN ARROW buttons. The date and time is displayed as the format you set. The time is displayed in 24-hour format. After confirming all settings are correct, press the SET button. The setting will be stored and the screen will return to the Setup2 menu.
Jul 05, 2008 | Cameras
Kodak EasyShare M1033 Digital Camera Logo
254 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
