Question about Homelite 'Yard Broom' Leaf Blower
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
My redmax eb7001 starts fine but it dies when I try to rev it up? I let my neighbor borrow it over the weekend and it started this behavior when I go it back start ok with choke on run but soon when choke is turn off cant rev up and die
  • 46 Answers
If he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Posted on Jun 02, 2009
Weedeater 25 cc gas leaf blower-only run on full choke and raise back up and it ies.Any solutions??
The raising or reving back up before it dies is a sign of fuel starvation. Check the diaphram in the carburator.
Mar 06, 2012 | Homelite 'Yard Broom' Leaf Blower
My homelite leaf blower will start up with the help of starting fluid but then dies out as soon as the choke is let off
Again the carburetor needs to be cleaned or the filter in the tank is clogged
Mar 01, 2010 | Garden
THE ENGINE RUNS FINE FOR 10 SECONDS THEN KIND OF DIES OUT BUT WILL THEN RUN FINE FOR 10 SECONDS AND THEN DIE OUT
Try replacing the in-line fuel filter, the Air Filter and Spark Plugs. Also make sure that you are using the proper start up procedure. In many cases that means using the highest choke setting until the engine tries to start, then going to the next choke setting and so forth until you get to no choke. It is imperative that you let engine run for at least 5 minutes before use to warm up. This will ensure a longer life and consistent running.
Oct 06, 2009 | Homelite Consumer Products Backpack...
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
Hello:
Check the Exhaust Port and Muffler for Carbon Blockage.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 07, 2009 | Homelite 'Yard Broom' Leaf Blower
Starts and runs fine when cold, dies after 10 to 15 min.
i would try first change gas make sure its a mix of gas and 2 cycle engine oil,second new spark plug third make sure theres nothning in the gas line hope this helps
Apr 06, 2009 | Homelite Leaf Vac Attack
FXR suzuki 150 will idle but wont rev
i had the same problem ! i dont know how but there was water mxit in my tank and i dumpd the fuel then it was fine
Mar 16, 2009 | 2001 Suzuki FXR 150
Mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Nov 20, 2008 | Homelite Consumer Products MightyLite...
Homelite 'Yard Broom' Leaf Blower Logo
718 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
