Question about Frigidaire PLMV169DC Microwave Oven
Frigidaire microwave making noise and blue sparks
We have the same problem with the same microwave! From day one, brand new microwave and it sparks a blue light behind the wave guide cover and makes a noise like a bug zapper. What is the deal? Is this a bad microwave? It does it regardless of what we are cooking, but it sometimes stops for a little while and then starts back. Should we get rid of it?
  • ervancil Jun 03, 2009
    Thank you for the advice. I will try it and let you know the results.
  • Frigidaire Master
  • 9,047 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
They are often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jun 02, 2009
  • William Miller
    William Miller Jun 03, 2009
    Ouch. I'll be looking forward to hearing how it goes.
Was boiling water and running microwave and a popping sound and blue spark appeared, it still seams to be functioning normally but am worried about what happened???
if you mean you were boiling water in a microwave, then A) that is a dangerous thing to do as any liquid in a microwave is very volatile and B) were the dishes ,containers etc you had in the microwave free of all metal? as that is what would have made the blue spark , when the microwaves connect with metal
Oct 09, 2011 | Frigidaire PLMV169DC Microwave Oven
Microwave sparks and makes noise only when fixing microwave popcorn. Otherwise, microwave works fine. The microwave previously worked fine with microwave popcorn. This happened with another brand of...
Hello bruton. As a microwave oven ages, the interior paint often deteriorates as does the internal part that creates the micro waves.
Using this is not a good idea as there is now a fire hazard. The best solution is to replace the microwave. There are sales now and you can get a nice new one for under $100.
Joe
Thanks for choosing Fixya!
Mar 23, 2011 | Microwave Ovens
Plmv169dcc WILL NOT HEAT. dOESN'T MAKE NOISE. ALL ELSE WORKS
the unit inside the microwave that heats food, called the "magnetron" has gone bad or the circuits that power the magnetron have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days
Jan 14, 2010 | Frigidaire PLMV169DC Microwave Oven
My frigidaire microwave does not go on
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and very detailed symptoms, answering these questions:
- Is it dead? (meaning there is no display, no light when you open the door, and no beeps when you press a key)
- Does it run but no heat? (meaning the inside light, cooling fan, and turntable all work)
- Does it make any unusual noise?
- Is it louder or quieter than normal?
Nov 25, 2009 | Frigidaire FMT116E1B Microwave Oven
When I turn it on it makes a noise like it's sparking but it's not. There is a piece of cadboard on the inside right that is all burned what can I do.
Any burned material must be removed as it is CONDUCTIVE and will absorb further energy from the microwave.
Never run the microwave without adequate food/water/etc as that can cause arcing.
Sep 10, 2009 | Frigidaire Built-In Microwave
Plmv169dcd
Similair problem, but no spark issue, just stopped working. No power at all...nothing. The unit is dead. What could be the problem?
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
Blue sparks from my panasonic over the range microwave
We have blown four... yes 4 over the range microwaves from Panasonic. Are we the only ones having this problem?
Dec 20, 2008 | Frigidaire FMV145K Microwave Oven
Popping and shooting sparks
Hi There!
Check behind the "Wave Guide Cover" on the inside cavity. There may be moisture or food residue behind it. Should be a cover that is plastic or Mica. Really strange that it's sparking being new. Also check that you use plates without gold or silver trimmings (Crockery or porcelein). This will also cause sparking. Remember that microwaves will always go to the first organic source in its path. The wave guide cover, if soiled, is very close to the tip of the Magnetron and will therefor result in arcing. Good Luck, JUS004
Feb 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave was working now making funny noise and not heating food and this is a brand new microwave and because i live in the virgin islands they are telling me the warranty cant be covered but the virgin...
I am having the exact same problem. There was a large POP and now it makes a weird noise and doesn't heat. Everything else appears to work though. I think it may be the HV Capacitor. Before I tear this thing off the wall and check the Capacitor does this sound like it may be the problem?
Jan 08, 2008 | Frigidaire PLMV169DC Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
1,404 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
