Question about Honeywell Programmable Thermostat Heater
2 zone sytem main floor cooler than what i set it to
I have a robertshaw 9600. 2 zone. I used the upstairs thermostat for the first time today and the main floor thermsostat was set at 80. upstairs at 81. when i came home the downstairs temp on the thermostat said 77 and it was definitely that temp. could the upstairs where it is very hot have somehow overcooled the main floor?
    President:
  • 3,433 Answers
Warm air rises and if the upstairs thermostat is on it will onerride to lower the temp upstairs. To have the dowstairs thermostat govern, the up stairs must be off . The whole house will balance to the controlling thermostat.
Posted on Jun 02, 2009
How to fix robertshaw thermostat display after changing batteries?
How To Replace Thermostat Batteries - YouTube
? 1:46
www.youtube.com/watch?v=QFd5jGL6vpM
May 10, 2012 - Uploaded by KungFuMaintenance Kung Fu Maintenance demonstrates how to change out thebatteries on most digital air conditioner and heater ..
Sep 19, 2015 | Robertshaw Thermostat Accessories 9010-1...
My Robertshaw 9600 displays 99 degrees and because it is satisfied, is not calling for heat. The temp is actually in the lo 60's and falling. I've tried battery replacement, but nothing changed. Other...
Hmm. I don't think it posted the first time around. So I'll try again.
There is a temperature sensing diode on the back side of this thermostat's circuit board. This diode may have failed or become disconnected.
I'd lean towards its having become disconnected, as I've been inside an example of this Robertshaw (originally Maple/Chase) 9600 thermostat and noticed that the soldering on this part was of poor quality. So if you have a soldering iron, and know how to use it, you could probably fix it.
I have a web page (just the facts, no ads, malware or fluff) that talks of some other common problems with this thermostat and how to fix them:
http://greyghost.mooo.com/maplechase9600/
Feb 04, 2010 | Shaw Robert RS-9420 Thermostat
How to install maple chase 9600 thermostat
The manual is very specific.  http://www.icca.invensys.com/manuals/robertshaw/110-653B.pdf    The Robertshaw 9600 is the same unit. The terminals marked RH, RC, W, Y, G are where you put the wires, just loosen the set screws with a small flat head screwdriver, insert the bare wire into the hole and tighten the screw. Leave the jumper between RH and RC for most installations. The red wire goes to the RH. Please come back and comment if you need more specific help. Good luck
Jan 08, 2010 | Heating & Cooling
I've noticed two problems with my heating system, but not sure if they are related. Here's the background - sorry for being so long winded. Background: I have a Weil-Mclain Gold CGi Series 2 (which was...
Two problems, one is a bad thermostat on zone 2. The second is the boiler. The inducer fan energizes causing a pressure switch to engage. This pressure switch energizes the ignitor. If the ignitor does not get hot enough, it will cycle again all over. The cheapest route to take is to check all hoses going from fan housing to pressure switch looking for bad connections or leaks, the second thing to do is to replace your ignitor (time for it anyway).
Jan 05, 2010 | Heating & Cooling
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Repace the tstat. Bad display. Make sure the batteries you put in were good First. Russ
Jul 25, 2009 | Heating & Cooling
RobertShaw Thermostat 9600 problem
verify if you have separate units for each floor.
the ones working could be a complete separate unit from the one having problem.
look at the condensing units you got outside , how many are there?
if you have 3 units outside and you have 3 thermostats, then each thermostat is controlling individual split units.
we have to concentrate on the one that is not cooling. give me the details on what is going on with problematic one.
is the outside unit running?
is the outside fan running?
can you distinguished if the compressor is running the same time as the fan?
tnx 4 using fixya,
drcool
Sep 14, 2008 | Heating & Cooling
Heating & Cooling Logo
190 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
