Question about Canon PIXMA iP90 Mobile Printer
Canon Pixma iP90 - Jagged text and lines
My Canon iP90 started printing text & lines that are jagged. I've run "deep cleaning", "print head alignment", and "nozzle check" and the problem is still there. What should I do next? I've always been happy with the print quality before.
  • 71 Answers
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Posted on Jun 02, 2009
  • sharon smith Aug 15, 2012
    where are these bands and how can you get to them to clean them
I had the same problem. Probably occured as I didn't use the printer for a while and the ink inside dried up ro something. I just replaced the cartridge with a new one and worked fine.
Posted on Jun 16, 2009
How do i stop it printing jagged lines
Run the print head alignment procedure in the printer driver. That is what it is for.
Jul 07, 2014 | Canon Pixma MX452
We are trying to get our iP90 printer to print. We have cleaned the print head, replaced both black & color ink. We have done a deep cleaning several times, cleaned with alchol & cotton q-tip....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Apr 04, 2011 | Canon PIXMA iP90 Mobile Printer
Ip90 does not print black
Make sure that the printer ink was not empty. On some cases the print head could be clogged or it was dirty, run a printer maintenance and do a deep cleaning on the printer print head.
Hope this initial info helps.
Let me know for further instructions.
Dec 09, 2009 | Canon PIXMA iP90 Mobile Printer
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Canon iP90 will not print black text - it will print any other color text. When I print a test page - it only prints the small flag top left page. I have done a deep cleaning - three times. I have replaced...
Hi Karen - it might be that you need some time to let the ink absorb into the pads in the print heads - this can take between a few hours and a day according to reports i found on this site, Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually - there are some great tips in the forum posts for this.
Hope you problem sorts itself out soon - take care
Chris
Dec 14, 2008 | Canon PIXMA iP90 InkJet Printer
hi karen,
If you are sure that the ink is present, there two other possibilities: Purge unit work properly so the ink cannot flow down from ink tank or Logic board of you printer is faulty.
Dec 13, 2008 | Canon PIXMA iP90 InkJet Printer
Print head for Canon Pixma ip90 not working
take print head out of printer and put a couple of drops of inkjet cleaner on the gauzes, dab off, reassemble and run the deep clean a few times. Printer should then work.
Nov 04, 2008 | Canon Office Equipment & Supplies
Canon PIXMA iP90 Mobile Printer Logo
564 people viewed this question
old marine
old marine
