Question about GE GSF25TGW
GE GTS22WCMBRCC, refrigerator and the freezer wont cool or freeze
I have a GE GTS22WCMBRCC that was working perfectly until we had a power outage, the power outage must have lasted about 10 hours or so, when power came back on, the refrigerator and the freezer will not cool or freeze, I did not see any leak in the back from the refrigerant, but not really sure. Any support will be greatly appreciated
    New Friend:
Possibly the drain tube for the condensate(water) is plugged due to ice having built up on freezer coils. Check coils to see if they are iced up. Sometimes especially in humid climates the defrost mechanism even if working gets overpowered by moisture. If so defrost coils manually and clear drain tube.
Posted on Sep 06, 2014
  • 163 Answers
SOURCE: GE refrigerator TDX11SNYAWH.
check your defrost timer and see if it is stuck in defrost.
Posted on Mar 07, 2009
freetek
  • 5568 Answers
SOURCE: Refrigerator and Freezer Not Cooling nor Freezing
That leaves only one possible fault; the volatile component of your coolant/lubricant has escaped.
If the unit has been moved or cleaned carelessly, one of the coolant- bearing tubes has developed a leak. Any refrigeration tech will have a leak detector in his tool set so it shouldn't be difficult to find.
Depending on the area in which you live, expect the troubleshooting and recharging to run ~$150-$250 US.
If you reside in the US, check your local (area) Better Business Bureau for a trustworthy service company.
Posted on Mar 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Posted on Mar 25, 2009
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
aasc
  • 1606 Answers
SOURCE: 15 yr old GE TBX18SA refrigerator. Not cooling.
Remove the screw , on the left side of the control panel , and pull the panel , from the left side , outward to the right . You should now see , slightly to the right , from the middle , a black screw , a hole with slot , and slightly higher to the right , a hole with a white piece , with a hole in it . Now , the hole with the slot , turn with a screwdriver , until you hear/feel a louder click . Turn this slowly . When you hit the right click , the refrig will shut off . Remove the inside rear freezer panel ( and ice maker if equiped ) , by removing 3 or 4 screws , pop off the grill piece , and may have to twist the ice maker receptical slightly , to remove . If you do not see the heater on ( red ) , below the coils , then the heater is most likely the problem . pt # WR51x464 . Your old one , has a glass tube , but the new one , is calrod . I believe 2 screws hold this heater on .. If the glass heater does come on , then the problem is the defrost timer ( the piece you turned with the screwdriver ) which is removed , by removing that black screw and bending the panel out slightly . Pt # WR9X520 .
Posted on Nov 04, 2009
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Refrigerators
Refrigerator cool freezer not as cold as it should be
try turning of the frige and let it be of for 1day then put back on and see if will works usally does,if not next usally is the compressor does give enough cold.motherboards dont go bad usally very rare,check all the above before you buy motherboard.please leave comment,vote,note.thankyou
Sep 13, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSF25TGW Logo
297 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
