Question about National Little Tikes Hummer Yellow
I need to remove the rear tires on a little tikes hummer h2,
How do i get them off? I have the exact problem as peterlyn, is the push nut the exposed circular piece on the outside of the tire??
    An expert whose answer gotĀ voted for 100 times.
    Habit-Forming:
  • 156 Answers
Yes,
Pull the push nut off with a pair of pliers. You will not be able to use them so you can get the extra ones at http://www.shopjandl.com/
You can also email them and they will have they will answer any question you have about these.
Hope this helps
Posted on Jun 02, 2009
How to replace brushes when they will not come out normally?
I had the same issue. Turns out the brushes were fused into the brush mounts. I pulled on the copper end cap and wire only to break it off at the carbon brush end. I had to pull the motor out of the housing (stator) to expose the brushes. I then used a tool to push the carbon brushes back in and out of the brush mount assembly. You could also push from the outside in, just make sure you get all the carbon pieces and use a tool that won't put scratches in your brush housings. My brushes where well over 1/2 inch long....but they were just fused into the assembly, so the spring wasn't pushing it properly against the commutator, which I am guessing was the reason my saw just stopped in mid use....I had ripped a straight line in a board and stopped for a few seconds to reposition the saw only to find it no longer worked.
Apr 28, 2014 | Makita 7 1/4" Circular Saw 5007NB
The front door handle lacks tension and the door won't open from the outside. However, the door will open from the inside.
I just bought a 96 transport with that same problem on both front doors they would open from the inside but not the outside. They have a design flaw, basically when you pull the handle it pushes a piece that pivots and in turn pushes a linkage rod downward that actuates the door latch, well that pivot point is the weak spot, the pin that it hinges on is too small and will break, (I found the pivot piece and the linkage rod laying in the bottom of the door)
If you pull the door panel off their are 2 nuts holding the door handle on, take those off and the door handle will come off, the pivot pin is on then inside of the door handle, what I did was to drill a hole and put a small self tapping screw in to replace the pivot pin, and hold the pivot piece and linkage in place then put it all back through the door handle hole in the door, and set the linkage down in it's hole in the door latch assembly. The screw I used was not exactly the same size as the original pin was so the pivot piece had some play in it and did not quite push the down far enough to unlatch the door so I put two small nuts to act as washers on the bottom of the linkage rod so it would push down a little more, now it works like a charm, on the other door the linkage rod had just come out of it's hole in the door latch assembly, all I had to do was pull the inside door handle, which lowered the door latch piece and guided the rod back into its hole as I released the inside door handle and now it works too, took about an hour for both doors, a fairly easy fix, hope this helps.
Dec 15, 2010 | 1996 Pontiac Trans Sport
We just purchased the 30th Anniversary Cozy Coupe and I messed up with the right and left side front wheels, I put them in the wrong sides. I need to switch them but the red Metal Cap Nut in the front...
I have dealt with many of these metal push nuts, best thing is to break the plastic off with a needle nose or regular pliers and then that will expose the metal push nut, then you can bend that with the pliers and pull it off and swap the tires to the correct sides, keep in mind this will ruin the push nuts and new ones will need to be ordered off ebay or something similar
Aug 15, 2017 | Little Tikes Cozy Coupe 30th Anniversary...
How to replace hub assembly on a 1999 cheve silverado driver side only! And what tools needed
2 wheel drive?
1 jack, 1 jackstand, 1 lug wrench,1 pair of channel lock pliers,1 pair side cut pliers1 3/8 or 10mm allen wrench, 1 six to 8 inch c clamp, 1 small pry bar grease,rags,.
place jack under truck same as changing tire,jack up and put jack stand under frame,remove tire,then using allen wrench,s remove allen bolts on inside of brake caliper,pry caliper off gently so as to not damage the brake pad,use a piece of wire and hang caliper so it does not hang on brake hose,then pull or pry the center hub cap off this will expose the bearingretaing nut there should be a cotter key in front of the nut,use the side cut pliers and straighten the cotter key then pull it out,remove the retaining nut and and crown washer,then pull the hub and bearing assembly off.
installation is in reverse,put hub and greased bearings on spindel tighten center nut while turning hub and tighten the nut very tight,the hub will be very hard to turn then start loosening the spindle nut and spinning the hub,holding the top of the hub push in and out if you feel it rocking on the bearings it is to loose tighten the slowly until there is no play put a cotter back in, put the small hubcap back on then using the c clamp and a piece wood put the c clamp over the back of the brake caliper and slide the piece over the piston cup on the inside to protect the piston,tighten the clamp until the piston is colapsed all the way, put brake pads back on put caliper on,put a small amount of grease on the smooth part of the allen bolts not on the threads,tighten the bolts.
put the tire assembly back on,remove jack stand and jack,
this is the important part,
1 be sure all bolts and fasteners are on and tight.
2 when you get in the truck and start it leave it in park,gently push the brake pedal down part way and let up do this until the pedal becomes firm.
3 after you drive five or ten miles recheck every thing.
Hope this helps.
May 14, 2010 | 1999 Chevrolet Silverado 1500
How do you get spare tire out from under van never used before and dont know how to get it loose
in the back storage area there is a circular plastic cover about 1.5" wide. pry this up with your tire tool and you'll find a hex nut. use the tire tool to loosen that nut and the tire will lower on a wire rope with a T handle in the center of the donut spare. reverse the procedure to replace it making sure you snug it tight.
May 03, 2010 | 2002 Dodge Grand Caravan
Cant release spare tire from under car of 2002 mercury villager. no owners manual available.
Location of the spare tire and tools
The spare tire and tools for your vehicle are stowed in the following
locations:
Item Location
Spare tire Under the vehicle, just forward of
the rear bumper
Jack assembly Under the third row bench seat in
the tool bag
Removing the jack and tools
1. Lift the 3rd row seat cushion.
2. Remove the jack assembly from the bag under the seat.
Removing the spare tire
1. Open the liftgate, locate the U-shaped slits in the carpet, and flip up
the piece of carpet to expose the hex nut.
2. Insert the lug nut wrench on the
hex nut in cargo floor.
3. Turn the wrench
counterclockwise until tire is
lowered to the ground and the cable
is slightly slack.
4. Remove the retainer from the
spare tire. It may be necessary to
lift one end of the tire to disengage
the retainer
Jul 12, 2009 | 2002 Mercury Villager
I can't removing rear tire
The outside cover? Can you see the lug nuts? If it is just the outside cover just use a tire iron or crowbar and gent;y pry it off. If you can see lug nuts then proceed and take em off, following safety procedures.
Dec 28, 2008 | 2003 Pontiac Bonneville
STUCK ON STANDBY
I took the ****** apart and found two spring-loaded black triangular plastic pieces poking out of two rectangular chips about 2mm square, just below the circular piece on the outside of the camera that changes mode – play, video, camera. Actually I found one of the above, because the second triangular piece was stuck in the closed position. A bit of jiggling and voila the problem was fixed.
That was the good news. The other news is that I must now reinsert inside of the shell a black circular piece of plastic that affixes to the rotating circular piece on the outside of the camera that changes the mode. When properly attached this circular piece manipulates the triangular pieces to change the mode.
I think that the likelihood of getting this piece properly aligned and affixed so that it moves the triangular pieces properly when the mode knob is rotated falls into the statistical probability range of pork taking wing. But worth a try.
Sep 04, 2008 | Fuji FinePix A345 Digital Camera
National Little Tikes Hummer Yellow Logo
324 people viewed this question
Top National Toys Experts
Joseph Hoffmann
Adam Fjeld
Adam Fjeld
Vernon Taylor
Are you a National Toy Expert? Answer questions, earn points and help others
