The fuse is located on the back of the unit underneath the rear cover which is fastened by 1/4" screws. Remove the screws, cover and you'll be able to check for continuity across the fuse. Of course you should make sure to unplug the unit before servicing. Hope this helps.... Bill
Roper model. 5 years old. The timer clicks and works. The door switch works. I connected the 2 wires...
(More)
Roper model. 5 years old. The timer clicks and works. The door switch works. I connected the 2 wires from the thermal fuse to bypass it. It did not start. For a week or so, I could smell something comming from the dryer room. Looked at the belt and it seemed fine, motor does move freely. Is there another fuse somewhere to test. AND if I need to take off the barrel to get to the motor, book says turn clockwise, but I didnt have success. Could you explain how to hold whatever needs held to get it off. So, is how can i check the other fuse, where is it? and Do I need to take the barrel off and how?
Roper Model #RED4000SW0--no heat...I have the back of the dryer off, but don't see where a fuse is...
(More)
Roper Model #RED4000SW0--no heat...I have the back of the dryer off, but don't see where a fuse is located...HELP ME!!
our dryer does not heat up at all to dry our clothes it operates as expected except for that one...
(More)
our dryer does not heat up at all to dry our clothes it operates as expected except for that one problem
the dryer seems to be running fine but it's like the pilot light isn't on adn i don't know where to...
(More)
THE DRYER SEEMS TO BE RUNNING FINE BUT IT'S LIKE THE PILOT LIGHT ISN'T ON ADN I DON'T KNOW WHERE TO FINE IT ON THIS DRYER
my roper dryer rgs748bkq2 is not putting out any heat. there seems to be no other problem with it....
(More)
MY ROPER DRYER RGS748BKQ2 IS NOT PUTTING OUT ANY HEAT. THERE SEEMS TO BE NO OTHER PROBLEM WITH IT. DOES IT HAVE A PILOT LIGHT AND IF SO WHERE IS IT LOCATED. JUST BLOWING COOL AIR.
