Question about Sharp LC-32D40U 32 in. HDTV LCD TV
Sharp LC-32D40U shows no video few seconds after turning it ON
If it is started it works good. Tried to tap it while working to see for loose connection but it stays on.
  • 4 Answers
I have the same model about 3 yrs. old. No picture but has sound.The problem is a loose contact in the circuit board. First unplug the tv and remove back cover. The circuit board opposite side of the input plugs. Remove this circuit board and clean the mating surface between the board and the mount. Reinstall board and tighten the mount screws. Reinstall back cover. Thats it. This is where your lost contact is occuring. Good luck
Posted on May 07, 2010
  • 405 Answers
Modification of the inverter unit usually takes care of this problem.
Posted on Oct 25, 2009
Sharp lc-32d4ou screen blacks out
I do have a work around that I have used on this model for the past3 years. if the sceen goes black. Turn off the tv. Grab the upper left and right hand corners of the tv with your hands. Flex the tv slightly back and forth. then turn it back on. my will usually run for hours after I do this. I do this 4 times a week. I works 100% if the time for me. Sharp lost a customer. good luck.
Aug 31, 2010 | Sharp Aquos LC-32D40U Television
What's the reason to cause the TV shows up only sounds but not pictures?
I may have a work around for you. I also have this model and the same problem. after trying many many sequences of turning on and off with setting changes I came across something that works for me 100% of the time. Turn off the tv. Place your left and right hand on the top corners of the tv. flex gently back and forth. turn tv on. this works for me. I can only say that this tv has some quality control issue(s). it will be my last Sharp product. this was a lowest bidder produced by a company other than Sharp with a Sharp label on it. good luck.
Aug 15, 2010 | Sharp Aquos LC-32D40U Television
Sharp aquos model LC-32D40U screen goes black
The Sharp TV model LC32D40U / 41U "Black Screen problem" is a very well known issue. The inverter is losing ground contact which will prevent the back-light from staying on. The solution is to re-tighten six screws on the inverter board. You also would want to clean the copper contacts on then bottom of the inverter where the screws go through. Access to the inverter board will require some disassembly. Plan on taking at least three hours to repair. See the photo for the location of the screws. Use some "blue" locktight" on these six screws. There is actually a Sharp Technical Service Bulletin that describes these screws. Sharp wants you to replace these screws with a newer version. They cost at least $2.50 each! I think my method will work just as good using the "Locktight"_548.jpg_547.jpg
Apr 20, 2009 | Sharp Aquos LC-32D40U Television
Picteru darkens to much
There are two settings within you menu that controls the brightness of what is going on. OPC, and Active contrast. Turn both of those off and you should have some luck.
Feb 05, 2009 | Sharp Aquos LC-32D40U Television
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
Probelm with wide screen display .
Check your VIEW MODE button instead ....
Aug 17, 2006 | Sharp Aquos LC-32D40U Television
Sharp LC-32D40U 32 in. HDTV LCD TV Logo
106 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
