Question about Sony Handycam DCR-SR42 Camcorder
Questionmark on my touchscreen where a picture file should be
I have 1 file on the touch screen with a question mark, why? can it be corrected?
  • 643 Answers
The data is corrupt. delete. try another icon. if does the same you have to format the hard drive
Posted on Jun 02, 2009
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
Touch screen for MC9000
the motherboard could be going out the machine would need to be checked
Mar 15, 2012 | Janome Memory Craft 9000 Computerized...
I have the macbook pro since February It has a question mark blinking on the screen
where is the questionmark? the questionmark usually means somethings supposed to go there and its missing
May 11, 2011 | Apple MacBook Laptop Computer Mac...
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
Konica Minolta Bizbub C253
To output a TX Report after every fax transmission, perform the following:
1. Press the Utility/Counter key.
2. Touch [3. Administrator Setting] on the touchscreen.
3. Enter the Administrator password (default password is 12345678).
4. Touch [OK] on the touchscreen.
5. Touch [7. Fax Setting] on the touchscreen.
6. Touch [7. Report Settings] on the touchscreen.
7. Touch [TX Report] on the touchscreen.
8. Touch [ON] on the touchscreen.
9. Touch [Exit] on the touchscreen to return to the normal copy screen.
Please send posotive feed back if this helps.
Aug 06, 2008 | Office Equipment & Supplies
Sony Ericsson K850i Have had this mobile since January (Brand New) - Last night the touch screen started to operate on it's own accord. Whilst texting the 'Back' button (right side of the touch screen)...
touch screen might have lost its sensitivity so take it to service center they will correct the sensitivity level ........this problem exists in almost all kinds of touchscreen phones ......
Jul 11, 2008 | Cell Phones
JIVA TP-5800 touchscreen problem
try cleaning the touch screen glass between the glass and the frame, if that fails, you need to replace the touchscreen glass
Jun 08, 2008 | Posiflex Jiva 5800 All-In-One...
Nintendo DS touchscreen problem
try calibrating the touchscreen....
Jan 08, 2008 | Nintendo DS Console
Sony Handycam  DCR-SR42 Camcorder Logo
65 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
