Question about Samsung DLP HL-P5663W 56" TV
LOUD, DISTINCT SNAP CRACKLE OR POPPING SOUND FROM SPEAKERS
SAMSUNG TV HL S5086W SOMETIMES THERE IS A SNAP, POPPING, CRACKLE NOISE FROM SPEAKERS. USUALLY IN THE EVENING WHEN THE TV HAS BEEN ON FOR A WHILE.
SOURCE: Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Posted on Sep 01, 2007
  • 1694 Answers
SOURCE: Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Posted on Nov 09, 2007
  • 7 Answers
SOURCE: Samsung DLP TV shuts off
Hello All, I may have an inexpensive solution to your problem. I had the same problem with my TV as well. It would shutoff by itself about an hour after it was turned on. The when I would turn it on again it would shut off after 5 to 10 minutes. Finally I got fed up. I knew it was not my bulb because the picture still looks good. I did here a buzzing if I would turn the TV on right away after it would shut off. That was do to the bulb recharging itself. I noticed the TV was extremely hot in the back. So automatically I thought it was the cooling of the set. All post I read keep saying the TV would last about 2 years to a year after a service. Which would be right because (most) service repair clean out the units before installing new parts. What I did was I opened unplugged the TV from the wall and opened unscrewed the back panel door. I used my Air compresser and blew out all the dust inside. ( A can of compressed air should do the job if you do not have a compressor) I removed the bulb and blew out the dust on the bulb as well. I did not remove the bulb from the housing unit. After I dusted the bulb and housing unit I reinstalled it. I keep my home clean but you should have see all the dust that came out. The dust covering the components overheat the unit which causes it to shutdown. It has been about 2 weeks and have not experienced any problems since. All I can say is give this a try and maybe this will work for you. This will only cost you about 10 dollars and 30 minutes of your time. This is better that Hundreds of Dollar in repair.
Posted on May 25, 2009
Angel Petter
  • 114 Answers
SOURCE: My Samsung HL-S5086W DLP TV which is about 3 years
Have try to reset your TV?
have you ever change your lamp?
No? the problem is the lamp..
Yes? try to close the back door of your TV
here are some examples!
and a link that it can help..
http://www.discount-merchant.com/SearchResults.asp?Search=lamp
Posted on Feb 05, 2010
  • 55 Answers
SOURCE: Samsung HL-P6163W Dlp TV has a loud humming sound
If you get a chance. Please post more details. Specially about the sound you hear in the back of tv is it like a humming or buzzing?
Posted on Mar 29, 2010
Why would our Samsung MN HL 850 86W make a crackling noise after it warms up? It sounds like the cracking of a fire. What could it be?
Your lamp ballast is going bad. Might last a few more months, but eventually it will have to be replaced. Bulb will also likely have to be replaced at same time, but try the ballast first.
May 04, 2014 | Samsung HL-S5086W 50" HDTV
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Getting a loud popping noise thur speakers till it warms up , samsung dlp hl-s4676s
Check the highvoltage board for a loose solder joint. Sound like a loose solder joint.
Jan 27, 2011 | Samsung HLS4676S Television
Replaced the lamp in Samsung hl-s5086w and now T.V. won`t turn on but has a high pitch noise coming from back of set.
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
Dec 13, 2010 | Samsung HL-S5086W 50" HDTV
How can I get rid of the popping noise?
It is the speakers on the tv fluxing sound is too loud. Change your bass settings or use a different sound system.
Jun 03, 2010 | Vizio VO320E LCD TV
Samsung dlp model hl- S5086W making continious humming noise, has nothing to do with volume. Can I replace fan or wheel myself?
Most likely color wheel since most are defective right out of the factory--- someone has a step by step procedure to replace with pictures-- try google- samsung colorwheel -- fun job easy to do!!!
Jan 04, 2009 | Samsung DLP HL-P5663W 56" TV
Snap Snap Pop
Nov 09, 2007 | RCA F32450 32" TV
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
Samsung DLP HL-P5663W 56" TV Logo
367 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
