Question about Tecumseh Garden
Oil coming out of muffler and carb
Tecumseh 6.0 is pouring oil out of exaust and intake port
  • 1 more comment
  • supehoneybun Jul 24, 2009
    sorry for not responding for got all about the question thank you for the tip i will try it
    THANK YOU
  • panilling9
    panilling9 May 11, 2010
    check your oil level?
    is it overfull?
    Did you have whatever the 6 hp is on on its side ?
    need more detail to help but if any situations mentioned? start it and let it smoke and it will clear up after running for awhile
2 Suggested Answers
  • 66 Answers
SOURCE: 13 hp tecumseh riding mower won't start unless gas is poured into carb. removed the bowl from carb has a wire snap holder float and needle and seat works OK and all passageways seem to be clean
hi
remove the bowl again and get the centre jet out and lok very closely use a jewlers eye piece you wll find a passage that is plugged on the side of the jet look around it you ll see some sign of a hole that is not clear through its pretty small use a welders torch cleanng tool with various size rods use very thin one dont make the hole bigger
Joe
Posted on Oct 10, 2012
Testimonial: "thanks for the ideas on fixing my problem I'm going over to my neighbors on Sunday and I'll try out your suggestions thanks again Al"
I have a 028 WB will not start without pouring gas in the carb as a primer , it has a new carb and fuel line and filter
1) Is the piston/cylinder condition good? It can be checked by removing the muffler and inspecting thru the exhaust port.
2) Is the impulse tube from the crankcase to the air filter housing in good condition? Make sure the impulse hole on filter base is not plugged. Apply as small pressure to the hole and listen for it to come into the lower end of the crankcase. You have to remove the carb to do that.
3) Is the intake manifold boot free of cracking or splitting?
4) When mounting the carb, no gaskets or sealers are to be used. The sealing ring on the intake manifold will take care of that. The impulse hole on the filter base will match up with the hole on the carb.
5) the worst case is that the crankshaft seals are leaking.
Jan 22, 2017 | Garden
Fuel pours out the air intake
if it like my 16 hp mower the carburator float is stuck take it off and check.
Dec 27, 2013 | Tecumseh Enduro Horizontal Engine 5 HP...
5 hp tecumseh no power
you need to remove carb for cleaning... if it has an adjustment on the bottom of carb try turning it SLOWLY in and out... also possibly a screw on the side under a black cap... might try it as well engine model number would help here
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Engine will not go to high speed fuel oil mist blows out .checked spark arrestor ,muffler,exaust ports.
If the mix is blowing out the muffler than it is flooded either due to improperly adjusted carb, stiff diaghrams in the carb or weak spark. Weak spark could be a bad plug, failing ignition module, or spark ouit of time ( sheared flywheel key).
Bad fuel will also cause this symptom.
Oct 25, 2012 | Troy Bilt Tb320bv Spring Assist Blower/Vac
hi
Joe
Oct 01, 2012 | Tecumseh Garden
Engine won't go to high speed,fuel mist blows out carb soaking air cleaner cover
Great explanation, You have a blocked exaust. Either the spark arrestor is blocked, or the muffler is plugged, or you have a plugged exaust port.
The best way to figue this out is to take the muffler off and shine a flashlight into the exaust port and look for carbon build up. You should see the piston go up and down, the whole port should be open. If it is blocked, clean it out with a scrapper. Make sure the piston is in the up position before you start scrapping( to keep the carbon out of the cylinder), Then wash the carbon out with spray carburetor cleaner. Then start the engine and it should run like normal ( loud but normal). The next thing is to clean the spark arestor screen, Hold it with pliers or a vise and use a torch to burn the carbon off. Once the screen gets red hot it will cook the carbon right off.
Hope this helps
Nov 14, 2010 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Need instructions for reinstalling throttle linkage for tecumseh vantage mower 1990's vintage
You have to take the carb and exaust intake off (they should be attached anyways) so you can turn the carb at the right angle to reinstall the cable.
May 05, 2009 | Mtd 22" Yard Machine Push Mower
Cbr 929 gas smell from muffler
Sounds like the floats in the carburetor are not shutting the needle valve, allowing excess fuel to be blowing out the cylinders, and blowing out into the muffler.
Check carb float and needle valve, Could possibly need a rebuild, Most floats today are a solid float and cannot allow gasoline to soak into the float, if it is by chance made of brass, could be filling up with gasoline and causing the float to stay low, not closing the needle valve.
Apr 30, 2009 | 2001 Honda CBR 929 RR Fireblade
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Mar 16, 2009 | Coleman Powermate Powermate 5000W...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
1,148 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
