Question about Sony VAIO GRZ610 Notebook
Sony Laptop GRZ610 Shutdowns
The laptop shutsdown repeatedly while running word or google or??.
Restrating again and it shuts down in a few minutes. If let alone for an hour it will work for an hour.
Is this an overheating problem?? or ??.
  • PRIUS Oct 25, 2007
    I put an Ice Pak Under it and it ran all day no problems.
    There was no dust in the fan.
    Clearly an overheating problem, as when the Ice Pak melted, it shut down.
    Sony has a design problem.
  • PRIUS Feb 16, 2008
    I bought a $10 fan with cloth blades and placed it behind the computer and have it blowing at the backside RH looking from the front.
    No problems over the last 30 days with the fa,
    Cheap fix.
    Problem Solver:
  • 12 Answers
I have the same laptop and had similar issues. My issues started a few months after maxing out the RAM. The problem was with the 2nd memory slot. I don't remember the exact problem, but the store that fixed mine had to re-solder the memory slot.
I believe if you only use the first memory slot it will boot up fine. It is only when the 2nd slot is used that the "shut down issue" starts.
John Lox
Posted on Nov 21, 2008
  • 64 Answers
Try placing a vacum cleaner nozzle on the bottom of the laptop flush up against the fan grill.  Make sure the laptop is off.  This should suck out the strip of dirt that tens to block the fan exhaust.
Posted on Oct 24, 2007
  • Fred Steinberg
    Fred Steinberg Oct 25, 2007
    Please note that you cannot see the dust strip unless you take the laptop apart.  Try the vucum trick.  It cannot hurt.
    If you put your hand by the output vent and you feel just heat and nothing blowing, it is blocked by dust.
Toshiba satellite p300 shutdown
You also should change the thermal paste. If you want to play games, please choose normal PC. I think you are asking too much from your laptop.
Apr 15, 2013 | Toshiba Satellite Computers & Internet
Laptop just shuts down.
If the System is hot when it shuts down, it overheated. if its not to hot, then the AC Adapter or Battery Failed.
Apr 13, 2010 | Gateway 7330GZ (890552601318) PC Notebook
Sony vaio system becomes hot and shutdowns
More than likely the fan above the processor is not working. Or the vents are clogged on the computer case due to dust/dirt. Ventilation.Check the fans.
Nov 22, 2009 | Sony VAIO VGN-CR510E/L Laptop
Gatway Laptop screwed!
There are several registry scan/fix programs on the Internet. Use Google to search for them and select one to suit you.
May 14, 2009 | Gateway Computers & Internet
Acer laptop
Press the power button until your laptop shutsdown. Start it again in safe mode and try to restore it to an earlier state that you think was the date problem was not there yet.
Sep 12, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Vga driver
download the driver and simply install
goodluck. please rate this solution after
Apr 14, 2008 | Sony VAIO GRZ610 Notebook
HP Pavilion zd8000 unexpected Shutdowns
Hi, There might be 3 possibilities why your laptop is shutting down: 1. You have a shortcut key in your keyboard that is pressed (accidentally or reacting to other keystrokes) that is configured to shut down your laptop; 2. You have a virus that is programmed to shutdown your laptop after a pre-determined amount of time; and/or 3. Your battery and/or AC adapter is no longer capable of supplying the power needs of your laptop. A few things you can do: a. Verify/Check if you have enabled any key stroke shortcuts for a quick shutdown; b. Check your Control Panel, Power Options, Advance tab, for any autoshutdown features, disable; c. use a known good/updated anti virus program and scan your drives. It might also be a good idea to run a program similar to Ad-Aware to scan for malicious ads; d. Charge your battery overnight and see if the problem persists. Or run the laptop with the AC adapter always plugged in to the mains and to your HP Pavilion ZD8000. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 01, 2007 | HP Pavilion zd8000 Notebook
Sony VAIO GRZ610 Notebook Logo
135 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
